Q about : what size pipe with SPOON n1?
Old Nov 12, 2004 | 03:46 PM
.water's Avatar
Default Q about : what size pipe with SPOON n1?
Finally i ordered SPOON N1
my queation is what size of header + cat + B-pipe should i use later?
Spoon N1: 60.5 mm = 2.38 inch
1st: 2.25
2nd: 2.5 (is it ok to use 2.5 inch? .am i gonna lose some HP? cause it's getting little smaller at the end)
Old Nov 12, 2004 | 03:49 PM
^MikeG's Avatar
isnt the spoon axle back 2.5"?
Old Nov 12, 2004 | 03:58 PM
.water's Avatar
Default Re: (^MikeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^MikeG &raquo;</TD></TR><TR><TD CLASS="quote">isnt the spoon axle back 2.5"?</TD></TR></TABLE>
most people tho its 2.5 but its not..like i said its 2.38..60.5mm
Old Nov 12, 2004 | 04:09 PM
^MikeG's Avatar
oic...i have no idea man, sorry
but ik alot of people on here have the spoon...so im sure you'll get the help
Old Nov 13, 2004 | 12:00 AM
.water's Avatar
anyone?
Old Nov 13, 2004 | 12:41 AM
:jdmshmaydm:'s Avatar
Default Re: Q about : what size pipe with SPOON n1? (Bee8teenSee1)
I'm using the T1R b-pipe with my Spoon N1. The Spoon N1 is bigger in diameter than the T1R last I checked. I don't know the exact dimensions of either though.
Old Nov 13, 2004 | 10:26 AM
ej0513's Avatar
i bought a OEM EK9 b-pipe.. exactly the same size as the N1... thats actually my whole setup right there..
Old Nov 13, 2004 | 10:33 AM
aZnjCC's Avatar
i'm curious as well. I have the spoon axleback, but I just got a jdm dc header. I can do 2.5" piping all the way back to the axleback right?
Old Nov 13, 2004 | 10:34 AM
ej0513's Avatar
^^ or you can do simple bolt on which would work probably then best and even sound the best.. JDM cat and EK9 b-pipe..
Old Nov 13, 2004 | 11:16 AM
-Infinity-'s Avatar
Default Re: (ej0513)
I am running the spoon n1 with a stock ek9 b pipe. I like the set up because I can also use my stock dx muffler with the b pipe.
Old Nov 13, 2004 | 11:38 AM
ej0513's Avatar
^^ exactly!!
Old Nov 13, 2004 | 11:44 PM
.water's Avatar
ok good info's..but i still want answer about pipe size
Old Nov 14, 2004 | 02:13 AM
ej0513's Avatar
well.. personally i would just get the OEM pipe but if your stuck on getting a custom pipe i would say get the 2.5.
Old Nov 14, 2004 | 03:23 PM
-Infinity-'s Avatar
Default Re: (Bee8teenSee1)
Use a 2.5 B pipe. Its not that hard. And you never told us what kind of header and cat (test pipe) you have.
Old Nov 14, 2004 | 03:36 PM
beedoublejay's Avatar
I use 2.25 cat and piping
Old Nov 14, 2004 | 04:30 PM
.water's Avatar
Default Re: (-Infinity-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Infinity- &raquo;</TD></TR><TR><TD CLASS="quote">Use a 2.5 B pipe. Its not that hard. And you never told us what kind of header and cat (test pipe) you have.</TD></TR></TABLE>
iam talking about What size header+cat+b-pipe..all of them with Spoon N1
Old Nov 14, 2004 | 04:50 PM
no2unenolife's Avatar
Default Re: Q about : what size pipe with SPOON n1? (beedoublejay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beedoublejay &raquo;</TD></TR><TR><TD CLASS="quote">I use 2.25 cat and piping</TD></TR></TABLE>
Old Nov 16, 2004 | 04:07 PM
.water's Avatar
Default Re: Q about : what size pipe with SPOON n1? (climaxpinoy)
will stock motor have differnt HP? using 2.25? or 2.5? its will be same right? 2.5 will be just bigger but same HP out of from 2.25
Old Nov 16, 2004 | 04:56 PM
-Infinity-'s Avatar
So how do you shift from first to second gear?
Old Nov 16, 2004 | 06:59 PM
IntegraBoy04's Avatar
Default Re: Q about : what size pipe with SPOON n1? (-Infinity-)
Babes99GSR has the Spoon N1 with a Type One b-pipe and Toda header. By the way, it's 2.5" piping.
Old Nov 17, 2004 | 02:48 AM
.water's Avatar
Default Re: Q about : what size pipe with SPOON n1? (IntegraBoy04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">Babes99GSR has the Spoon N1 with a Type One b-pipe and Toda header. By the way, it's 2.5" piping. </TD></TR></TABLE>
thanks alot man..thats what i wanna hear.. also thanks to rest of peeps
mtny
Aug 21, 2007 02:15 PM
mikkey1
Jun 9, 2006 10:46 PM
SixPAK
Mar 5, 2003 09:29 PM
EGtoR
Jun 27, 2002 05:44 PM
