Brake problem
Old Nov 12, 2004 | 03:12 PM
Lorolla's Avatar
Default Brake problem
Hi, did a search already. I undid one bolt on the brake caliper to take off my pads and while the caliper was swung up I pumped the brakes to see if the piston was working fine. But the problem is now the piston is extruded a lot and i cant swing the caliper back into place. How do i make the brake piston move back down???
Cheers
Old Nov 12, 2004 | 03:20 PM
eda6's Avatar
Default Re: Brake problem (Lorolla)
C-clamp for the front calipers. Big screwdriver for the rear calipers. Do not push in the rear piston. The rear piston must be turned clockwise. Take the lid off the mc when you're pushing the piston back in. Hopefully your caliper isn't ruined
Old Nov 12, 2004 | 03:33 PM
Lorolla's Avatar
Default Re: Brake problem (eda6)
so do need to use the c-clamp to push the front piston back in??? so you cant push in the front with your hands, right??
Old Nov 12, 2004 | 03:44 PM
eda6's Avatar
Get a c-clamp. An 11" c-clamp is $10 at home depot. Make sure the piston goes in straight or you'll get squirted with brake fluid and also have a ruined caliper. Brake fluid eats paint so be careful. You shouldn't be able to push it in by hand.
Old Nov 12, 2004 | 04:03 PM
Lorolla's Avatar
It doesnt seem to be goin back in even with a c clamp. Does this mean I have to bleed my brakes?
Old Nov 12, 2004 | 04:34 PM
eda6's Avatar
If you bleed you brakes you'll probably push the piston completely out. The piston needs to be installed to bleed the brakes. It can be rebuilt. I'd just get a new caliper if i were you.
Old Nov 12, 2004 | 04:35 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lorolla &raquo;</TD></TR><TR><TD CLASS="quote">Does this mean I have to bleed my brakes?</TD></TR></TABLE>
At this point, you may as well put new seals in it, because you've probaby mangled the seals and a leaky caliper is no fun. Although I might suggest finding someone who has a little more experience, so you have functional brakes when this is all over.
Next time put a block of wood in the caliper when you press the pedal!
Old Nov 14, 2004 | 09:10 AM
sabotage7's Avatar
is your brake fluid cap off while you're using the c-clamp?
Rampaging Llama
Nov 5, 2005 12:54 PM
crxcess
Oct 9, 2002 10:50 AM
wickedxbo1
Dec 30, 2001 08:19 PM
wickedxbo1
Dec 30, 2001 07:51 PM
