SEARCHED: 90-91 HB Seat Install in 88-89 HB
Old Nov 12, 2004 | 01:01 PM
JapJunkie's Avatar
Default SEARCHED: 90-91 HB Seat Install in 88-89 HB
Okay well its time to sell my 88 STD, When i bought it, it had no front seats. So i have 90-91 Si seats to put in it. The hatch didnt come w/ rails either. I recently came up on some. So now im trying to swap the 88-89 seat rails onto the 90-91 Si seats. I have heard that u just swap the rails over and thats it, but no luck. Only one side of the rail bolts onto the seats, The side that just moves up and down. It seems like the side w/ the handle on it (the one U pull up to move back and forth) has no way to bolt onto the 90-91. They are diff. mounting holes. I can take pics if it will help, so lmk if i should snap some.
Does anyone have any info. on how i can pull this off??? I have heard and seen it done. thanks in advance
Old Nov 12, 2004 | 01:06 PM
eumoria's Avatar
Default Re: SEARCHED: 90-91 HB Seat Install in 88-89 HB (JapJunkie)
you need to get 88STD seat pans and swap the whole bottom
SEEARRCCHH
Old Nov 12, 2004 | 01:07 PM
JapJunkie's Avatar
Default Re: SEARCHED: 90-91 HB Seat Install in 88-89 HB (eumoria)
Seriuos no way around it?
eumoria's Avatar
well you can modify it with metal if you cut and drill, but no you need to swap the pans
it's not difficult to do, just unbolt top half, and pop the pins holding the fabric on
Old Nov 12, 2004 | 01:15 PM
JapJunkie's Avatar
The thing is i have no 88/89 seat pans I mean i do but i need them I have my 89 Si seats and my jdm ZC seats but i need those for the hatch that i am going to keep
Old Nov 12, 2004 | 01:33 PM
lunchboxEF91's Avatar
im pretty sure there are plenty of seat pans out there in the junk yard. I had to switch out some 89 si seat pans with my 91 seats to make them fit. Good luck
Old Nov 12, 2004 | 04:18 PM
JapJunkie's Avatar
Default Re: (lunchboxEF91)
Was it easy?
Old Nov 12, 2004 | 04:51 PM
speeddave's Avatar
Default Re: (JapJunkie)
yup it is, did the same thing to make my si seats work, used dx seat pan.
JapJunkie
92
Feb 3, 2011 04:05 PM
+honda_monkey+
Jul 30, 2009 04:52 AM
HybridHatchEF9
May 1, 2007 03:16 PM
Ghett0_ed
May 14, 2006 10:45 PM
SLIPSTICK TIPPIN
12
Apr 4, 2006 06:56 AM
