f22b1 block h23a1 block
Old Nov 12, 2004 | 11:16 AM
preludesi93-arg's Avatar
Default f22b1 block h23a1 block
is the same block the f22b1 and the h23a1
in the link is number 1
http://www.hondaautomotivepart...L+PAN
Old Nov 12, 2004 | 11:21 AM
PirateMcFred's Avatar
Default Re: f22b1 block h23a1 block (preludesi93-arg)
No they are not. but you can put the H23 head on the F22 block in the form of a hybrid.
Pirate
Old Nov 12, 2004 | 11:40 AM
Default Re: f22b1 block h23a1 block (PirateMcFred)
if the CRANKSHAFT , SHAFT, FR. BALANCER , SHAFT, RR. BALANCER ,ROD, CONNECTING is the same , wath is the mayor diferents..
Old Nov 12, 2004 | 11:49 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludesi93-arg &raquo;</TD></TR><TR><TD CLASS="quote">if the CRANKSHAFT , SHAFT, FR. BALANCER , SHAFT, RR. BALANCER ,ROD, CONNECTING is the same , wath is the mayor diferents.. </TD></TR></TABLE>
Smaller bore and different piston wall lining.
Old Nov 12, 2004 | 11:58 AM
Default Re: f22b1 block h23a1 block (AndyD)
yes bore f22b1 85 mm
bore h23a1 87mm
thank honda-tech
AirbornManJuice
Jan 20, 2015 09:54 AM
bjones
Apr 19, 2008 09:13 AM
HYREV2NR
Nov 23, 2007 10:18 PM
Linus_E
Mar 23, 2005 04:52 AM
