TB gasket / IM cleaning
hello everybody
- can i use 0.4mm flexoid to make TB gasket?
- who can i clean the intake manifold ? can i use the STP carburetor spray?
best regards moshik galimidi
yes that will work for the TB,
If the IM is off the car Carb cleaner is a good way to clean it, pull the stock injectors and clean them up to. If its still on the car use Seafoam.
As said above yes you can make your own TB gasket, but you might be better off just going to the dealership and getting the correct one for your throttle body. I've heard of countless vaccum leaks being the result of a wrong TB gasket... HTH.
Brian
Brian
about the leaks... is it ok to use 2 gaskets?
i will post a picture of my homemade gasket and you will tell me if its good.
and yes. the manifold is off the car.
are you sure that its ok to clean the injectors with the STP ?
civic_driver
Sep 25, 2005 11:51 PM
