CAR PROBLEMS!!! grrr...
Old Nov 12, 2004 | 10:29 AM
Prelude Chick's Avatar
Default CAR PROBLEMS!!! grrr...
Since i've owned my 93 Honda Prelude SR, soo much ish has happened to it.. I lived downtown so it got jacked and broken into so many times.. spent $700 on compustar alarm.. still got jacked....
leaks oil....
3 weeks ago had the rotor and distributor cap replaced by honda for $2000
My NEWEST PROBLEM is...
i was driving yesterday and my car kinda jerked or jumped...later on that day i noticed the transmition light was flashing... then when i was pressing on the gas there was no power!!! but it was revving.
I took it home and checked transmission fluid and it seems fine...
Do i need a new transmission?? what's wrong?? and is it bad if i keep driving it even though it seems fine now???
1993 Honda Prelude SR
Old Nov 12, 2004 | 11:05 AM
Honda Sport's Avatar
is the car an auto or manual? could be that the axle popped out, has happened to me a few times, or bad axle, or bad tranny.
do I sense sarcasm or did you really spend $2000 on a new cap and rotor? hahaha...
Old Nov 12, 2004 | 11:11 AM
Hawkze_2.3's Avatar
Default Re: CAR PROBLEMS!!! grrr... (Prelude Chick)
You did not seriously pay $2000 for a cap and rotor?!? $200 is way to damn much...
Auto or manual?
Old Nov 12, 2004 | 11:24 AM
Jagan'92's Avatar
Anyhow, I assume you have an auto, because you have a transmission light blinking. Low tranny fluid level will definately over-rev when you accelerate, so check the level, or even drain and refill. Smell it to see if it's burnt.
If there is a fuel problem causing that bucking, you should get a CEL.
Old Nov 12, 2004 | 11:37 AM
kellyk75's Avatar
Default Re: CAR PROBLEMS!!! grrr... (Jagan'92)
if your tranny light is on but the gears won't enguage, that sounds bad. Take it to a tranny shop and have them open it up and take a look. I am not sure about 4th gens, but I don't think they have to pull it to open it. You can probably have an inspection done for under $100, but a new tranny will run you quite a bit.
So none of the gears work..... is that what I am reading?
Old Nov 12, 2004 | 11:55 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Chick &raquo;</TD></TR><TR><TD CLASS="quote">
WHATTT?????!!
A cap and rotor is like $40!!
take the car to a mechanic you trust, maybe get your fluid changed
Old Nov 13, 2004 | 11:12 PM
PrettyLude's Avatar
2000 dollars, man if you paid that much for a cap and rotor, they screwed you in the *** without grease
lude_chick
Apr 1, 2020 10:28 AM
teamdeguzman
Dec 21, 2013 04:48 AM
SuperFetch
Aug 17, 2013 11:44 AM
HSPxNick
Feb 16, 2006 04:06 PM
samdawgsol
Sep 9, 2004 10:10 AM
