Which piston? (not the usual piston questions...)
hi, i am doin a report for one of my college classes. My report that i have chosen to do is to compare these three pistons JE PISTONS WISECO PISTONS and ARIAS PISTONS. I am supost to research these pistons and do a report explaining which would be the better choice for my car... all i'm looking for is some input and tips on these pistons so i can use the given information as a "source" for my research project. all you guys here on HT have helped me alot in the past and i hope you can help me out with this. i'm looking to run 9:1 comp. but i dont even thing ARIAS makes a 9:1 for my application....
My set up is:
92 honda accord
OBD 1 JDM H22A ( i know i have to have the block sleeved to run most of those pistons)
8LB Fidanza Flywheel
Pro Clutch stage 3 clutch
light LBS crank pulley
aem fuel rail
TURBO SETUP
t3 super 60
SS crap mani with wastgate (I know i know it will crack blah blah blah)
Uberdata
i'm going to be using some pritty big injectors and tune down (not sure what size)
3in custom downpipe
sol dual core radiator
Thanks in advace!! any help is welcomed!!
My set up is:
92 honda accord
aem fuel rail
TURBO SETUP
t3 super 60
Uberdata
3in custom downpipe
Do it based on price since you aren't running power levels where stock pistons would finch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord »</TD></TR><TR><TD CLASS="quote">t3 super 60
not another one.
not another one.
yeah i forgot to mention in there that i was only going to be running like 6-7 lbs... but... when i do "need" the pistons that i'm asking about i will be running the sleeved block with a bigger t3/t4 on hight boost levels... so, i guess just pretend that i am running high horse power and bigger boost....
