rockers good to use or not?
OK, well I'm getting a b16 head that appears to have starved for oil. the cams and journals are a little messed up. there ground down a little. I'm not so much interested in the head, but do you think the rockers would have gotten messed up?
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">with out pictures, this is pointless</TD></TR></TABLE>If the lobes on the cams show wear then I can guarantee you that the pads on the rockers also have wear, which means that they are junk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo »</TD></TR><TR><TD CLASS="quote">If the lobes on the cams show wear then I can guarantee you that the pads on the rockers also have wear, which means that they are junk.
i can guarantee you that the rockers could be fine
</TD></TR></TABLE>i can guarantee you that the rockers could be fine
eg_nezay
27
Jul 15, 2004 09:55 PM
