Koni yellow question
Old Dec 25, 2001 | 10:34 PM
Greyout's Avatar
Default Koni yellow question
the koni yellow shock has an adjustable spring pearch, correct?
I've heard you can make like a 1/2" inch adjustment in your ride height... is this adjustment up or down? I have too much ride hight in the rear when compared to the front and want to drop it a little bit more without buying new springs.... if I get the koni yellows in the rear, can I put it on the lowest spring pearch and make it a bit lower then normal, or is there only a "NORMAL" and "HIGHER THEN NORMAL" setting?
Old Dec 25, 2001 | 11:03 PM
carsaregood's Avatar
Default Re: Koni yellow question (JDM LUDE)
I have the koni yellows for my car, and the highest setting in the front is lower than where the stock shock puts it. As for the rear, I'm pretty sure you can go lower than the stock shock allows... higher? I'm not sure.. i forget.
Old Dec 25, 2001 | 11:07 PM
Greyout's Avatar
Default Re: Koni yellow question (carsaregood)
basically my front tires are slightly tucked but I still have a noticable gap in the rear... does anyone know for sure? btw my current rear shocks are tokico sports, so I am really just looking for comparisons between the koni and tokico spring perch....
g_teg
May 4, 2005 08:20 AM
dumbchild
Jul 11, 2003 03:24 PM
Razor
May 7, 2002 08:11 PM
coop94ls
Jul 31, 2001 09:56 PM
