Tire Size
Old Nov 12, 2004 | 09:34 AM
OBDII Integra's Avatar
Default Tire Size
Would it make a big difference if I got wider tires than stock but keep my stock blades....the tires i found were 205/50/15.. is it dumb to do this? Its just that there so much cheaper tha the stock size tire...$71 for stock..$57 for the wider ones. Any suggestions?
Old Nov 12, 2004 | 09:54 AM
vain's Avatar
Default Re: Tire Size (OBDII Integra)
i run 205/50/15s .. the difference isn't too noticeable.. the overall diameter is a little smaller, so your speedo will be a little off [ like at 80mph, your speedo will read like 81~82mph ].
and its usually more expensive for the 205s than it is for 195s .. so i dunno why you're getting a better deal on 205s. but i say go for it.
Old Nov 12, 2004 | 10:21 AM
Default Re: Tire Size (vain)
Does It make the look of the car like bad or nething? Like dos it make it looks like its sitting high and what not?
Old Nov 12, 2004 | 10:33 AM
batmang yO!
Guest
Posts: n/a
205's won't make the car look "bad". I put 195's on my GSR which hasn't been lowered and the tires look too damn scronny!! but if you can get 205's cheaper than 195's then ****! go for it, can't go wrong there.
Old Nov 12, 2004 | 10:43 AM
Honda Hick's Avatar
Get the 205/50s. They are cheaper than 195/55's because the 195s are a weird-*** size and you'll have a greater selection of tire in the 205/50 size. Also, you'll have better traction from a wider tire. The height of the 195/55's and 205/50's is almost identical. It really depends on the manufacturer when it comes to the exact height/width/etc. Check out the specs on each tire at http://www.tirerack.com and you can see exactly what the size differences are. I had 205/50's at one point and I really liked them. The car seemed to "track" alot better when going at higher speeds. Good luck
Old Nov 12, 2004 | 10:45 AM
Default Re: Tire Size (Honda Hick)
Thanks alot for the help...The tires I am looking to get are the Falken Ziex 512's..Nebody ahve these tires? if so, how do u like them?
Old Nov 12, 2004 | 12:10 PM
xprohx's Avatar
I think too much
^^ Had those tires after the stock tires. They worked well wet and dry.
Old Nov 12, 2004 | 01:04 PM
vain's Avatar
all about the yoko avs es100s :D
Old Nov 12, 2004 | 01:59 PM
Default Re: (vain)
i've heard real good things about those but i heard in the snow there horrible
Old Nov 12, 2004 | 02:04 PM
vain's Avatar
Default Re: (OBDII Integra)
yeah. they're summer tires. i didn't notice .. you're in NJ
Old Nov 12, 2004 | 03:24 PM
dFreezy's Avatar
Default Re: Tire Size (Beavis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beavis &raquo;</TD></TR><TR><TD CLASS="quote">205's won't make the car look "bad". I put 195's on my GSR which hasn't been lowered and the tires look too damn scronny!! but if you can get 205's cheaper than 195's then ****! go for it, can't go wrong there.</TD></TR></TABLE>
the '195' is the width of the tire. the other dimensions of the tire (wheel diameter and sidewall height) have more to do with how big or little the tire looks...
Old Nov 12, 2004 | 03:26 PM
Kn1ves's Avatar
Default Re: Tire Size (dFreezy)
I just got my 205/50/15s installed on mine with my Meshies and they look fine
Brewbot87
May 7, 2013 05:40 PM
em12nv
Mar 18, 2008 09:12 PM
tampabitches
Aug 24, 2006 01:26 PM
legends
Oct 2, 2005 02:09 PM
tibbor
Apr 5, 2004 07:02 PM
