when doing WOT pull on dyno oil pressure drops then comes back up
Old Nov 12, 2004 | 08:03 AM
Tex Blackwell's Avatar
Default when doing WOT pull on dyno oil pressure drops then comes back up
While on the dyno in 4th cruising at say 3k rpm, then rolling into WOT the oil pressure starts going up, then drops about 10psi (at probably about for about one second then oil psi just keeps going up normaly
this ever happend to anyone before?
Old Nov 12, 2004 | 08:04 AM
drdisco69's Avatar
Default Re: when doing WOT pull on dyno oil pressure drops then comes back up (mp3albums2k2)
That either the oil pressure relief spring or the oil filter bypass opening. I noticed it too, but it's normal.
Old Nov 12, 2004 | 08:07 AM
mmuller's Avatar
Mad Scientist
Default Re: when doing WOT pull on dyno oil pressure drops then comes back up (drdisco69)
yep, mine does it too
Old Nov 12, 2004 | 10:58 AM
Default Re: when doing WOT pull on dyno oil pressure drops then comes back up (mmuller)
oh ok, so nothing to worry about, i thought that was kinda funny, where is that at? it never happend on any other engine
Elevorett
10
Jan 2, 2010 06:23 PM
ALL IMPORT
Jul 23, 2006 02:43 PM
hondapwr
Mar 11, 2004 02:43 PM
