rear caliper problems need help
Old Nov 12, 2004 | 08:02 AM
vtecmissle's Avatar
Default rear caliper problems need help
i have a right rear caliper that just eats pads up in a month or so. i cant figure out why it does this the left is ok and so is the right front. I have already checked rotor runout and also put in new rotors and had a few machined. Anyone ran into this problem before.
Old Nov 12, 2004 | 08:13 AM
Rory Breaker's Avatar
Default Re: rear caliper problems need help (vtecmissle)
Yep. Check the pins, make sure they slide in and out freely. If not, pull them out and apply grease liberally. Slap it back together and hope for the best.
Old Nov 12, 2004 | 08:17 AM
JimBlake's Avatar
Default Re: rear caliper problems need help (newgsrdriver)
Do the pads fit nice into the caliper bracket? Sometimes I have to file the ends a little (thickness of the paint?) so they aren't wedged in too tight. They need to release when you let off the brakes.
Also-- Check whether the handbrake mechanism down in that caliper is releasing?
Modified by JimBlake at 1:56 PM 11/12/2004
Old Nov 12, 2004 | 08:42 AM
dip-set's Avatar
Default Re: rear caliper problems need help (JimBlake)
possible that caliper is seized or seizing as well
Old Nov 13, 2004 | 11:08 AM
vtecmissle's Avatar
Default Re: rear caliper problems need help (dip-set)
thanks for the suggestions i will check them all out. If i have to buy a caliper i will buy a whole aftermarket setup.
Old Nov 13, 2004 | 12:11 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the suggestions i will check them all out. If i have to buy a caliper i will buy a whole aftermarket setup.</TD></TR></TABLE>
dont you just love it when things (sometimes) goes wrong and you HAVE to upgrade?
only if you have the cash for it tho..
i cant think of anything else you can check that other people havent covered.. so good luck
Old Nov 13, 2004 | 11:42 PM
stumpyf4's Avatar
If the easy stuff doesn't seem to work (slider pins seized) then I'm gonna guess that the internal caliper parking brake mechanism is messed up. Happens quite often on Honda's, buy yourself a remanufactured caliper and you should be good to go.
Old Nov 15, 2004 | 02:31 PM
vtecmissle's Avatar
Default Re: rear caliper problems need help (stumpyf4)
i think your on to something here. It was very hard for me to turn the piston back in this caliper and the other side took half the effort. Also if i pull the ebrake at about thirty mph only the other side locks up. Leading me to believe the other side had tension already and the pads were hot. My local autoparts dealer said it was probably the ebrake tensioner also. Thanks.
Old Nov 15, 2004 | 03:46 PM
stumpyf4's Avatar
I agree... if the piston is hard to turn back in something is defintely hangin up inside. Change the caliper and you should be good to go.
kevinm1981
Aug 3, 2009 02:24 PM
PreludePhill
Feb 7, 2007 06:02 AM
PreludePhill
Apr 28, 2006 06:37 PM
b18c198
Oct 30, 2005 06:47 PM
kdogx
Oct 15, 2004 01:36 PM
