LS crank in a c1 block
Old Nov 12, 2004 | 07:29 AM
TegRaceR98's Avatar
Default LS crank in a c1 block
well i am building an LS vtec, but i came across a bare gsr block, noe can i use my mains froman LS on this block? and will the crank go in without and real hard modification? thanks in advance
cooley
Old Nov 12, 2004 | 08:49 AM
95 integra's Avatar
Default Re: LS crank in a c1 block (TegRaceR98)
i wouldnt cross the mains like that. You really need the gsr mains with block girdle....
Old Nov 12, 2004 | 09:15 AM
EdoMoto's Avatar
It will bolt on just fine. But before you do that you need to have a machine shop cut the caps and rebore the main bearing holes. Then you should be fine.
Old Nov 12, 2004 | 10:03 AM
TegRaceR98's Avatar
ok i ahve new ls main bearings, can i use gsr mains?
Old Nov 12, 2004 | 10:27 AM
dcb16's Avatar
Default Re: (TegRaceR98)
as long as they are within spec. and i suggest using a gsr girdle on an ls block, its veeeery nice. cheaper than the z10 and it does teh same exact thing. if u need info and how to do it, pm me
Agito
Sep 14, 2007 01:11 PM
pimpnpink
Feb 8, 2007 01:05 PM
PhantomRacerGSR
Mar 16, 2003 04:49 AM
eddiecut
Aug 20, 2002 10:14 AM
