What is the best choice GSR engine or Turbo ls?
Old Nov 12, 2004 | 06:35 AM
Drag305's Avatar
Default What is the best choice GSR engine or Turbo ls?
What is the best choice GSR engine or Turbo ls? I have a choice between a $2400 gsr engine (including install). Or turboing my ls. What should I do?
Old Nov 12, 2004 | 06:51 AM
mr.beeks's Avatar
Default Re: What is the best choice GSR engine or Turbo ls? (Drag305)
enjoy the beauty of v/tec
Old Nov 12, 2004 | 07:08 AM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">enjoy the beauty of v/tec
Old Nov 12, 2004 | 07:39 AM
.DOHChi
Guest
Posts: n/a
Default Re: What is the best choice GSR engine or Turbo ls? (93 Da 16a)
turbo that bitch. ****.
Old Nov 12, 2004 | 07:46 AM
b17hybrid's Avatar
Turbocharge all day.
Old Nov 12, 2004 | 07:58 AM
skunk2eg's Avatar
Default Re: What is the best choice GSR engine or Turbo ls? (b17hybrid)
here we go again....BOOST IT!
Old Nov 12, 2004 | 08:02 AM
the DA in HONDA's Avatar
Default Re: What is the best choice GSR engine or Turbo ls? (skunk2eg)
build the block and boooooost pshhht!
Old Nov 12, 2004 | 08:06 AM
lapok25's Avatar
Boost if the engine is still in good condition.
Old Nov 12, 2004 | 08:09 AM
virusiidx's Avatar
Default Re: What is the best choice GSR engine or Turbo ls? (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">enjoy the beauty of v/tec</TD></TR></TABLE>
no, enjoy the beauty of turbo
Old Nov 12, 2004 | 08:24 AM
m R g S r's Avatar
Lets see, 150 whp vs 300whp hmmmm??
Old Nov 12, 2004 | 08:25 AM
m R g S r's Avatar
Default Re: What is the best choice GSR engine or Turbo ls? (m R g S r)
You'd have to be a fucktard if you chose the GSR motor. Seriously, what's the point?
Old Nov 12, 2004 | 08:28 AM
skunk2eg's Avatar
werd...youd gain 38hp and 1 ft/lb of trq....worth $2,400 when you could run 7-8 pounds and own gsr's all day?
Old Nov 12, 2004 | 09:27 AM
sir boostalot's Avatar
why didn't you wait until you had enough money to just buy a gsr if you wanted one? Dropping a GSR in DC Chassis is definetely not worth the money or time. Turbo all the way.
Old Nov 12, 2004 | 09:34 AM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">werd...youd gain 38hp and 1 ft/lb of trq....worth $2,400 when you could run 7-8 pounds and own gsr's all day?</TD></TR></TABLE>
Drag305's Avatar
I think ill be purchasing a turbo. Thanx
Old Nov 12, 2004 | 10:01 AM
dcb16's Avatar
Default Re: (Drag305)
i think you should make goals for yourself... ie 13.0 sec all motor ek or 11.8 sec turbo ek ect ect. you should do that, and then decide what you want. or if you just want to be fast, then slap a turbo on that biznatch and let the rapage begin : )
Old Nov 12, 2004 | 10:49 AM
l2Y4N's Avatar
turbo ls fer sher
Old Nov 12, 2004 | 11:15 AM
Khelm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">You'd have to be a fucktard if you chose the GSR motor. Seriously, what's the point?</TD></TR></TABLE>
Ignore the lame post above... this guy clearly has no idea about the concept of tunning.
It is all a matter of what you want. Know this. Noone on this board will be able to give you a direct awenser. Because we do not know your goals for the car.
If you want a straight awnser, then post your goals.
Personally.... I would have no shame in building a b20 block installing a vtec head, and blowing all the N/A cars in your area out of the water. There is pride within having a All Motor car. Whats so great about running 7lb of boost?? HUH?
Now if you want to boost the damn thing then I say build your block first. This way you can be pushing a whole lot more boost and actually making it worth your money.
Both options are great, but remember what determines this is your final goal for the car.
Old Nov 12, 2004 | 11:17 AM
Khelm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">you could run 7-8 pounds and own gsr's all day?</TD></TR></TABLE>
Or you can make a $500 investment in Clutch/Flywheel and own GSR's all day....
Old Nov 12, 2004 | 11:22 AM
iBear's Avatar
Default Re: What is the best choice GSR engine or Turbo ls? (Khelm)
turbo
Old Nov 12, 2004 | 11:58 AM
boostjunkie757's Avatar
as much as i may like vtec....
boost &gt; vtec
of course, if you can afford to do both....
Old Nov 12, 2004 | 12:03 PM
xprohx's Avatar
I think too much
Default Re: (boostjunkie757)
Just boost it and come back and tell us how much you love it.
Old Nov 12, 2004 | 12:37 PM
SOmbooTy's Avatar
Yes yes, before you decide to boost it, you damn right should build your block and make sure you are ready to properly tune your setup there are many LS turbo setups on honda-tech so try hard to search out the threads... it shouldnt be too hard. Once you get boost, man will you be addicted and you will seriously be like AHHHH F*CK vtec =p
Old Nov 12, 2004 | 01:18 PM
KLeSe's Avatar
[QUOTE=Khelm]
First off, you would need a whole lot more parts than just a block and a vtec head to have a fast N/A car. Look to spend as much money for N/A parts as you would to buy a turbo kit. What kind of N/A cars will you be blowing with just a vtec head?
Second, the good thing about having 7lbs of boost is that I'll be ahead of you cuz you ain't got the power!
Old Nov 12, 2004 | 01:22 PM
Default Re: What is the best choice GSR engine or Turbo ls? (Hbadge4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hbadge4Life &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=Khelm]
Second, the good thing about having 7lbs of boost is that I'll be ahead of you cuz you ain't got the power! </TD></TR></TABLE>
good luck making 300+ hp without boost.....
