White Smokes on Vtec ??
Old Nov 12, 2004 | 04:55 AM
OLM-02R's Avatar
Default White Smokes on Vtec ??
wat could it be ?? i blow alot of white smokes when i hit vtec... anyone ?
Old Nov 12, 2004 | 05:28 AM
eRACING's Avatar
Default Re: White Smokes on Vtec ?? (OLM-02R)
blown head gasket
Old Nov 12, 2004 | 06:46 AM
BubblesLovesHisPussys's Avatar
Default Re: White Smokes on Vtec ?? (erics99si)
sounds like somehow there is coolant getting into the combustion chamber - most likely a blown head gasket as described above or a cracked block (probably not).
Old Nov 12, 2004 | 01:35 PM
OLM-02R's Avatar
headgasket's new...just got it rebuild 2months ago...coolant's still on max level...it only happen when i hit vtec... it doesnt smoke on idle or on start only when vtec...
its a different story if u blow ur gasket...coz it happen to me b4...thanx...
Old Nov 12, 2004 | 01:42 PM
tech1145's Avatar
Default Re: (OLM-02R)
You may not have blown your headgasket, it could just be a small hole that lets coolant seep in under the higher pressure of VTEC. Are you running forced induction?
Old Nov 12, 2004 | 01:43 PM
1BadCvC's Avatar
possibly the top of the block may be warped, allowing a little coolant to get burnt. Still its wierd it only happens at vtec..so idk, good luck
Old Nov 13, 2004 | 06:44 AM
asubennett's Avatar
Default Re: (1BadCvC)
Is the block sleeved? It could be the bottom of the sleeves are not fully seated. This happens from time to time.
Old Nov 13, 2004 | 01:03 PM
OLM-02R's Avatar
Default Re: (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Is the block sleeved? It could be the bottom of the sleeves are not fully seated. This happens from time to time. </TD></TR></TABLE>
nope the block is not sleeved.
Old Nov 13, 2004 | 01:05 PM
OLM-02R's Avatar
Default Re: (tech1145)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech1145 &raquo;</TD></TR><TR><TD CLASS="quote">Are you running forced induction?</TD></TR></TABLE>
nope im running N/A
Old Nov 13, 2004 | 01:09 PM
OLM-02R's Avatar
ok...this morning i let someone drive my car and see wat color the smoke is...its dark color ...i thought i see white smoke when i give it...
so i think im burning oil...i checked my oil level and its a lil lesser...
could it be piston ring ?
Old Nov 13, 2004 | 02:00 PM
Bserieskllr's Avatar
this is basically how colors for smoke goes
white-lean
blue burning oil
black-running rich
Old Nov 13, 2004 | 03:16 PM
miahmouse's Avatar
Default Re: (Bserieskllr)
white - COOLANT
you're thinking of plugs...
Old Nov 13, 2004 | 03:46 PM
Default Re: (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">white - COOLANT
you're thinking of plugs...</TD></TR></TABLE>
thanks my bad.
Old Nov 13, 2004 | 05:00 PM
86si's Avatar
sounds normal,my 92 GSR with 210k miles lets it be known when shes in vtec
Old Nov 13, 2004 | 10:12 PM
notstock93's Avatar
Default Re: White Smokes on Vtec ?? (86si)
could be a small leak thats being blown "clean" under load.
Im just grasping at straws, here.
Old Nov 13, 2004 | 10:24 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
what was the cylinder wall clearance, what breakin cycle did you run it through, what oil was in it during breakin, what weight is in it now. were the valve seals replaced
check your pcv valve. do you have a cold air intake or a clamp on filter on your valvecover breather?
lsvtec97hatch
11
Dec 19, 2011 03:01 PM
carlossolorzano
Jun 29, 2011 12:30 PM
caliEG2dr
May 15, 2010 12:44 AM
JDM B16A
Jul 20, 2006 03:29 PM
311
Sep 13, 2002 05:31 AM
