best cams for turbo???
Old Nov 11, 2004 | 09:38 PM
londa hover's Avatar
Default best cams for turbo???
right now i have enough money to go turbo. and i have skunk2 stage1 cams.
i want to go w/ 9.0:1 cr.
out of gsr,itr and skunk2 stage1 cams. wich would produce the most power w/turbo?
Old Nov 12, 2004 | 01:52 AM
BodyKits NW's Avatar
Default Re: best cams for turbo??? (londa hover)
I run some Rocket Motorsports cams and let me tell you. These suckers make great power all the way up to 9800. Probably even cheaper than the Skunk Stage 1. They are worth the investment. I can afford other cams on the market, and these are by far one of the pieces that make my motor make good power.
Old Nov 12, 2004 | 03:59 PM
Default Re: best cams for turbo??? (BodyKits NW)
what the specs on them do you know? are these cams for turbo?
Old Nov 13, 2004 | 11:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">right now i have enough money to go turbo. and i have skunk2 stage1 cams.
out of gsr,itr and skunk2 stage1 cams. wich would produce the most power w/turbo?</TD></TR></TABLE>
Old Nov 14, 2004 | 06:37 AM
turbo96wr's Avatar
we use int type-r's and also chuck from alternative moto........ work well for us.
Old Nov 14, 2004 | 12:24 PM
Default Re: best cams for turbo??? (turbo96wr)
well the skunk2 stage1 cams are barely more aggressive than itr's so should i use them? do you think id get more power over gsr cams w/ turbo?
Old Nov 14, 2004 | 12:27 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">well the skunk2 stage1 cams are barely more aggressive than itr's so should i use them? do you think id get more power over gsr cams w/ turbo?</TD></TR></TABLE>
Yes, the Stage1's will make more power than GSR's with a turbo. Go rocket though.
Old Nov 14, 2004 | 03:56 PM
speedtec11s's Avatar
Default Re: best cams for turbo??? (boosted92)
Skunk stage 1 cams are for all motor applications. Harv always had us use b16a cams....and we made a shitload of power with em. One of my buddies car did low 300's to the wheels (street car) and Harvs words were "wanna make 50 more hp? Slap some b16a cams in it"
Just my two cents...i got mad faith in big daddy harv
Old Nov 14, 2004 | 07:14 PM
boosted92's Avatar
Default Re: best cams for turbo??? (speedtec11s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedtec11s &raquo;</TD></TR><TR><TD CLASS="quote">Skunk stage 1 cams are for all motor applications. Harv always had us use b16a cams....and we made a shitload of power with em. One of my buddies car did low 300's to the wheels (street car) and Harvs words were "wanna make 50 more hp? Slap some b16a cams in it"
Just my two cents...i got mad faith in big daddy harv</TD></TR></TABLE>
50 more wheel hp with B16A cams, over what? Custom ground cams with 160/160 duration @ .050 and .200" lift? Boostfed made 40 WHP more with ITR cams than he did B16 cams at high boost, that's enough for me.
Old Nov 14, 2004 | 07:17 PM
boostismycrack's Avatar
E-thug
I put down 540 to the wheels this week with itr cams on 21 psi!
Old Nov 15, 2004 | 10:27 AM
Default Re: best cams for turbo??? (boostismycrack)
If I remember right the cams I have are 275/275 with 11.8 lift
They work great for me.
Old Nov 15, 2004 | 10:55 AM
BLK JDM's Avatar
I just bought a set of Blox Turbo Spec cams!! They look great but are not installed yet. Once installed I'll post up whether they suck or not!!!
Old Nov 15, 2004 | 11:05 AM
Mag00n's Avatar
Default Re: best cams for turbo??? (BLK JDM)
I would rather have cheap *** GSR cams with an ITR valvetrain that allows me to rev into the mid to high 9's. Remember its not the cams that allow you to rev that high its the valvetrain and on turbo cars the turbo is making the power at high rpms. Im not saying ITR cams didnt make more power than gsr cams, I'd like to see that dyno though. What I'm saying is even a stock b16 can make power well into 9krpm when boosted, its limited by the valvetrain capabilities though.
Old Nov 15, 2004 | 11:26 AM
Default Re: best cams for turbo??? (Mag00n)
For some reason my old b16 cams wouldn't make power past 8500rpm's before. I made good power with them, but I wanted to make power all the way to 9500. I have no problems making power past 9500 easily now. Rocket was able to hook me up with a profile that would work well with my setup.
Modified by BodyKits NW at 1:02 PM 11/15/2004
Old Nov 15, 2004 | 11:45 AM
ekb18c's Avatar
Type R y0!
Old Nov 15, 2004 | 11:59 AM
B18C4-T's Avatar
Default Re: best cams for turbo??? (ekb18c)
Tony1 told me to use a Type R intake and GSR exhaust cam. That's what I have right now, the car should (PLEASE GOD!!!!!!!!) be running by the end of the weekend and tuned in Jan so I guess I'll know then how the setup works. Larry
Old Nov 15, 2004 | 12:27 PM
11psiTurboSI's Avatar
Default Re: best cams for turbo??? (B18C4-T)
gsr cams or type r cams would be my choice
Old Nov 15, 2004 | 12:46 PM
civicsit's Avatar
Default Re: best cams for turbo??? (9psiTurboSI)
well i am working on a turbo build up.. and the cams i am going to try is comp cams stage 2 i have them already...lol
gezzuzz
Feb 13, 2008 03:28 AM
blakh
Jun 5, 2007 06:32 PM
s2kkk
Mar 19, 2005 01:13 PM
SiR Inspired ED7
Nov 7, 2004 01:27 AM
usdmcivic94
12
Jul 12, 2004 03:04 PM
