B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX?
Old Nov 11, 2004 | 08:32 PM
bboyoxygen's Avatar
Default B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX?
I'm looking at an Iceman intake and I was wondering which one I should buy?
92-95 EX or 94-01 GSR?
Old Nov 11, 2004 | 08:38 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (bboyoxygen)
what intake manifold are you running on your B18c ?
civic gtr's Avatar
i think si intake is ur best bet cuz the intake manifold of gsr is different from type r.
Old Nov 11, 2004 | 08:41 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (civic gtr)
Of course you'll buy the intake for the GSR.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboyoxygen &raquo;</TD></TR><TR><TD CLASS="quote">
92-95 EX or 94-01 GSR?</TD></TR></TABLE>
Old Nov 11, 2004 | 08:44 PM
1slow_dx's Avatar
i would get a gsr intake
Old Nov 11, 2004 | 08:46 PM
hondaeg8's Avatar
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (1slow_dx)
do not get a gsr cold air intake. i got one and the intake runs right in front of the resevoir tank. it works just fine, but it doesn't go through the hole on the side by the fender like it should. get a CAI for a 99-00 civic si.
are you using the stock gsr intake manifold?
Old Nov 11, 2004 | 08:47 PM
00Red_SiR's Avatar
All Motor Mentor
If you're runnign the stock GSR IM use a GSR intake, if you're using a Skunk 2 IM you would use an intake for an Si.
Old Nov 11, 2004 | 08:48 PM
litterbox's Avatar
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (hondaeg8)
Thought he meant short ram.
Old Nov 11, 2004 | 08:49 PM
hondaeg8's Avatar
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (litterbox)
i would just get the one for ths SI. eventually you should want to change out the stock gsr intake manifold.
Old Nov 11, 2004 | 08:50 PM
MassScene's Avatar
just get a short ram for now untill you figure out what your plans for the motor are.
Old Nov 11, 2004 | 08:52 PM
jdmsiR20's Avatar
lots of misconception going around here.
if you've got the gsr intake manifold, the gsr intake is what you need.
if you've got a si/type r manifold, a 99-00si intake is fine.
these are for cold air intakes...
and yes, the filter location will differ. reason being is because the gsr intake manifold locates the t/b lower than si's and type r's....
Old Nov 12, 2004 | 07:19 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">lots of misconception going around here.
and yes, the filter location will differ. reason being is because the gsr intake manifold locates the t/b lower than si's and type r's....</TD></TR></TABLE>
Isn't that what I said above? lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">If you're runnign the stock GSR IM use a GSR intake, if you're using a Skunk 2 IM you would use an intake for an Si.</TD></TR></TABLE>
Old Nov 12, 2004 | 08:08 AM
SOHCZCHatch's Avatar
AEM makes hybride intakes now but kinda expensive you just need to match your motor up with your car and they got the intake to fit your car right and give you the right amount of power gain
Old Nov 12, 2004 | 08:12 AM
bboylito's Avatar
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (00Red_SiR)
not meaning to thread jack but i have a 94 eh hatch with a d16z6 and a aem cai , i'm swapping a b16a2 can i use the same aem intake??
if not which one should i buy???
Old Nov 12, 2004 | 08:13 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX? (SOHCZCHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCZCHatch &raquo;</TD></TR><TR><TD CLASS="quote">AEM makes hybride intakes now but kinda expensive you just need to match your motor up with your car and they got the intake to fit your car right and give you the right amount of power gain</TD></TR></TABLE>
and that intake will go through the actual hole for the intakes on 92-95s, instead of smashing into your resevoir bottle before it makes the downturn.
i'd get one, but i went comptech instead.
primerk5
Jul 18, 2007 05:26 AM
epak
Sep 14, 2006 11:00 AM
cambopheonix56
Dec 20, 2005 10:04 PM
shervin
Jun 10, 2005 12:26 PM
vg7z
May 16, 2005 10:57 PM
