Help car is not starting !!! no power on the computer , injectors , fuel pump !!
Old Nov 11, 2004 | 05:09 PM
Cyber ITR's Avatar
Default Help car is not starting !!! no power on the computer , injectors , fuel pump !!
the car is actually an EF8 CRX , but i thought u guys care enough to help me
ok, heres the story
the car originally had b18c1 turbo engine, i have aftermarket wire-in computer , but still using my stock wiring loom from my b18c1
now i dropped in a jdm b18c R engine, still using my b18c1 wiring loom , i chopped some bits of sensors / plugs from my ITR wiring loom.
< distributor , alternator , crank pulley is from my b18c1 >
everything is plugged in and connected , but there is no ****** power on the computer and injectors !!!!!! the fuel pump is not even running !!!
the engine is cranking but thats about it
please help guys !!!!!
Old Nov 11, 2004 | 10:17 PM
drdisco69's Avatar
Default Re: Help car is not starting !!! no power on the computer , injectors , fuel pump !! (I See Dead Peo
Checky fuses?
Old Nov 12, 2004 | 01:00 AM
Cyber ITR's Avatar
fuses are in perfect condition , none blown
Old Nov 12, 2004 | 05:07 AM
JimBlake's Avatar
Main relay powers all 3 - ECU, injectors, & pump. Or maybe the main relay isn't getting trigger from the ignition switch. Got a multi-meter??
Old Nov 14, 2004 | 03:08 PM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Main relay powers all 3 - ECU, injectors, & pump. Or maybe the main relay isn't getting trigger from the ignition switch. Got a multi-meter??
are you talking about the main relay in a brownish box ???
Old Nov 14, 2004 | 06:29 PM
BIG RICH's Avatar
how about the grounds? the ground on the thermstat can cause some wierd problems.
Old Nov 14, 2004 | 06:39 PM
PrettyLude's Avatar
check all the grounds, check the ignition swithc
Old Nov 14, 2004 | 07:24 PM
Cyber ITR's Avatar
Default Re: (PrettyLude)
RUNNING TODAY , w@@t !!!!!!!
there was a bunch of loose wires around the thermostat , as soon as my mechanic tightened it up , w@@t got power straight away
thanks guys !!!!!!!
italian_virus
Oct 5, 2011 07:06 AM
Cyber ITR
18
Nov 15, 2004 05:39 PM
Cyber ITR
Nov 14, 2004 07:48 PM
jumpmann23
Aug 5, 2003 05:37 PM
