b18 into 89 hatch si
Old Nov 11, 2004 | 04:53 PM
trrbl1bmx's Avatar
Default b18 into 89 hatch si
i have a 89 hatch si . my friend wayne is selling a b18 out of his 1990 teg. what all would be required to do this swap. like what kind of mounts ect? thanks alot!
Old Nov 11, 2004 | 05:01 PM
Aylla
Guest
Posts: n/a
Default Re: b18 into 89 hatch si
You're going to need the whole engine and transmission, the ECU, both axles, halfshaft, and shiftlink. You're going to have to shorten the shiftlink to make it fit the Civic. Depending on if your car's a Dx or an Si, you'll have to rewire the harness. The motor mounts, you can find some cheap ones here for about $200.[more or less] Also, if it's a Dx, you're going to want the teg gas cable or an Si one.
Old Nov 11, 2004 | 05:42 PM
dvang's Avatar
Default Re: b18 into 89 hatch si (b-clubspecII)
do a search
Old Nov 11, 2004 | 05:51 PM
trrbl1bmx's Avatar
well yes of course ill need the engine. the engine came out of a 90 teg so does that means its obd0? i know my si is obd0. but other than mounts it should go together fine?
Old Nov 12, 2004 | 11:19 AM
Aylla
Guest
Posts: n/a
Default Re: (b-clubspecII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-clubspecII &raquo;</TD></TR><TR><TD CLASS="quote">well yes of course ill need the engine. the engine came out of a 90 teg so does that means its obd0?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-clubspecII &raquo;</TD></TR><TR><TD CLASS="quote"> i know my si is obd0. but other than mounts it should go together fine?</TD></TR></TABLE>
yeah
Old Nov 12, 2004 | 07:05 PM
turboimports's Avatar
Go to http://www.hasport.com they have a pretty good outline of what you need and prices.
-Lor
Old Nov 12, 2004 | 09:11 PM
streetlegal gocart's Avatar
Default Re: (turboimports)
24th post is unneccesary. Please search here and web.
LittlesilverEF
Feb 21, 2009 10:22 AM
MrXclusivE
16
Oct 19, 2008 06:01 PM
hondacivic0909
Jul 24, 2007 07:31 PM
itsJDMyo
Dec 4, 2005 06:07 PM
civicracer1993
Nov 7, 2003 06:35 PM
