b16a not getting enough fuel when reving, bad injectors?
Old Nov 11, 2004 | 04:18 PM
ewing86's Avatar
Default b16a not getting enough fuel when reving, bad injectors?
90 crx dx with b16a ran fine than, one of my wires for the multi point swap broke and turned off the injects and i didn't know so i put different injects in it. Fixed the wire and sometimes it needs help starting up so i spray some gum cutter in their and then it will idle fine by itself when i go to rev it, it bogs real bad, like you can hit the gas, if you move it with your hand on the tb very slightly u can get it to like 1800 but thats it. It bogs real bad and almost dies then u have to left off and will idle fine after that, no codes either. So when spary some gum cutter in their and rev it, it revs fine with no problems so i know its a fuel issue. Also my fuel gauge reads 70 psi, and it works fine that is a whole lot. Could the injects be backed up sending some fuel back in the line causing this pressure. It should be like 38 psi of fuel. I would put my old injects in but cant fine them and broke 2 of them and cant find anyone with a pair of b16 injects obd-0
br8crumb
May 22, 2014 04:53 PM
Blue94Accord
Oct 2, 2009 12:11 PM
yeahkkyle
Sep 23, 2009 02:24 AM
PwRLiMeH22
May 9, 2008 12:01 PM
untitled
Mar 11, 2003 04:20 PM
