Fuse Box cover missing under dashboard to the left.
Old Nov 11, 2004 | 03:41 PM
SexyAzNMami's Avatar
Default Fuse Box cover missing under dashboard to the left.
Hi, i found out some of my fuses has been blown out... for example it's label 7 and 9 that are blown out. It doesn't have a cover. The fuse is located on botton of the dash board near the driver side door. I don't have a fuse box indentifier. . can someone post me theirs? thanks alot .
Old Nov 11, 2004 | 03:54 PM
eda6's Avatar
Default Re: Fuse Box cover missing under dashboard to the left. (SexyAzNMami)
7 and 9 are not used in my car. What doesn't work?
Old Nov 11, 2004 | 04:03 PM
Zaakro's Avatar
Default Re: Fuse Box cover missing under dashboard to the left. (eda6)
here you go, i had to find something with a black background cuz its seethrough
Old Nov 11, 2004 | 04:07 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
from an '88 model:
http://img22.imageshack.us/my....1.jpg
from a '90 model:
Old Nov 11, 2004 | 04:09 PM
Zaakro's Avatar
Default Re: Fuse Box cover missing under dashboard to the left. (88DXCRX)
dude they are the exact same one from 88-91
Old Nov 11, 2004 | 04:16 PM
Default Re: Fuse Box cover missing under dashboard to the left. (Zaakro)
my selt belt lights keep coming on and it flashes along with a annoying beep beep every 3 seconds. I was thinking a fuse blew out . That's why i wanted to check the fuse box.
what could be the problem?
Old Nov 11, 2004 | 04:23 PM
88DXCRX's Avatar
They are basically the same but
Look at positions #12 and #17...
There is a slight difference in the charts anyway..
Old Nov 11, 2004 | 04:27 PM
Zaakro's Avatar
ahh ok i see it
Old Nov 11, 2004 | 04:59 PM
88DXCRX's Avatar
kewl
Not tryin to start a fight or anything...
just trying to provide accurate info just in case someone it saved for future reference....
On the later models with the seat belt warning sytem,There is a switch
inside the receptacle that senses when the clasp is inserted into the anchor.
Check under your seat and make sure the electrical connector is plugged in..
If it is,and it still does not work,unplugging the connector might
make it stop depending on what type of switch it is..
Also look inside the buckle for debris like a french-fry or a paper clip..
trust me...I have seen it before..
Modified by 88DXCRX at 8:12 PM 11/11/2004
Old Nov 11, 2004 | 08:17 PM
tried everything .. still not working . . . sob . .
is there a wire on the inner dash board to the flashing of the seat belts that i can cut? really **** right now . .haha
Old Nov 11, 2004 | 08:20 PM
88DXCRX's Avatar
Honda seat belts are warrantied for the "use-full life of the car"
It is a safety issue..
See thread: https://honda-tech.com/zerothread?id=1042924
If all else fails take it to the dealer..They should fix it for free..
.joeham
Honda Civic (2006 - 2015)
Feb 2, 2010 12:39 PM
terryle00
Jun 3, 2009 10:45 AM
kayelemenohpee
Sep 12, 2007 12:32 AM
EliteRacer05
Aug 5, 2005 10:01 AM
Guitarzann
Dec 30, 2001 10:36 PM
