Broken rear mount 2 times now... X-member is cracking...
Old Nov 11, 2004 | 02:45 PM
Blaze45's Avatar
Brrraaaap!
Default Broken rear mount 2 times now... X-member is cracking...
So I've had my B20 swap for a lil over a year now, and I must say I love it. Accpet that Im having a slight issue. The rear motor mount keeps breaking. I have had to have it welded twice. I got the mounts from Camp 1320 and they dont seem to give a rip about my problem. So this last weekend I was in the process of "trying" to swap in my GSR tranny, I noticed that my rear x-member is cracking where the two bolts go in for the rear mount. They are actually cracked pretty good. I dont do hardly any burnouts but it has had its fair share of full throttle shifting. When I floor the car I can slightly feel my shifter move (more so then the stock setup or just the motor flexing). I can also feel the motor swinging at sometimes. Is there anything that I can do to combat this? Would the jimfab x-member help with this at all? Any insight would be great.
tia
Blaze
Old Nov 11, 2004 | 02:47 PM
EL Vap133's Avatar
Default Re: Broken rear mount 2 times now... X-member is cracking... (Blaze45)
You can get a new rear cross member.
Old Nov 11, 2004 | 06:54 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Broken rear mount 2 times now... X-member is cracking... (EL Vap133)
Well thats good news, but what about my motor rocking issue? Is this normal for B swaps?
Old Nov 11, 2004 | 07:54 PM
paulzy's Avatar
do you have a front mount? if not, that's your problem
Old Nov 11, 2004 | 07:57 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Well thats good news, but what about my motor rocking issue? Is this normal for B swaps?
Well now that I got Hasport mounts, I have not encountered that problem anymore.
Old Nov 11, 2004 | 08:41 PM
Wink1100's Avatar
I got enjo mounts and never had this problem? oh yah, i had a b20 in my ef, jus don't rev to high, i blew mine up, number 4 piston went through my block and took out my rad. lol....in the middle of 97' GSR swap now, lol...
Old Nov 11, 2004 | 09:37 PM
EL Vap133's Avatar
Wait, what kind of clutch do you have? I used to have a 4 puck ACT unsprunged clutch, now I have a 6 puck sprung clutch.
Old Nov 11, 2004 | 09:41 PM
rasta420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You can get a new rear cross member. </TD></TR></TABLE>
where to get a new rear cross member and about how much?
thanks
Old Nov 11, 2004 | 09:54 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
ive got a few. email me.
Old Nov 11, 2004 | 10:30 PM
EL Vap133's Avatar
Default Re: Broken rear mount 2 times now... X-member is cracking... (rasta420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
Junkyard/salvage yard or a donor car.
Old Nov 11, 2004 | 11:17 PM
Rednas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote"> I got the mounts from Camp 1320 and they dont seem to give a rip about my problem. </TD></TR></TABLE>
That is one of the problems that many people face when they buy mounts from smaller companies. That sucks for you hope that you are able to resolve your problem.
Old Nov 11, 2004 | 11:27 PM
JapJunkie's Avatar
Post to let me know if getting a new rear X member does the job
Old Nov 12, 2004 | 01:32 AM
b18CrxSi91's Avatar
71.179.86.205
Default Re: Broken rear mount 2 times now... X-member is cracking... (JapJunkie)
I have the same problem with my LS swap, Its so bad that it would hit the firewall and that was the only thing stopping the motor from swaying.
Car is currently off the road for the winter the problem will be fixed.
Old Nov 12, 2004 | 01:34 AM
92integra_gs's Avatar
yea just get a new or used but exc cond cross member
Old Nov 12, 2004 | 03:20 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (92integra_gs)
Im using a clutchmasters stg 4. 4 puck clutch sprung. Ive finally gotten used to using it. It took quite a while tho. It hardly ever sees anything past 7k, stock head/bottom end. Where is this 4th mount that you speak of? It definetly needs one.
thanks
Old Nov 12, 2004 | 04:42 AM
rasta420's Avatar
Junkyard/salvage yard or a donor car. </TD></TR></TABLE>
is it difficult to remove the rear cross member? and is it ok to leave the engine on the other three mounts while replacing the rear cross member?
thanks again
Old Nov 17, 2004 | 09:59 PM
hey rasta, i found a shipper and need your info now.. if you already emailed me i cant find it so send it again.
Old Nov 17, 2004 | 11:23 PM
ServiceAdvisor's Avatar
Hmm, I've seen this problem before and someone had posted a link to a japanese company which had a stronger quality steel x member, was around ~$200 if I remember correctly.. Maybe you could find a metal fab shop and ask them to fab you something of a higher strength steel. Replacing it with a stock one might just result in a few thousand miles more before the problem arose again. IMO, mod cheap and you will mod twice. - Darrell
SoEvoL
Jul 14, 2006 08:27 PM
mikeunreal
Nov 24, 2005 04:19 PM
rice_classic
Jun 30, 2002 02:38 PM
KF_S2000
Apr 1, 2002 07:13 PM
