Selt belt light on beeping every 3 seconds .. . beep
Old Nov 11, 2004 | 01:33 PM
SexyAzNMami's Avatar
Modified by SexyAzNMami at 4:18 PM 11/13/2004
Old Nov 11, 2004 | 01:42 PM
dr_latino999's Avatar
Default Re: Selt belt light on beeping every 3 seconds .. . beep (SexyAzNMami)
Could you have shorted one of the sensors when painting?
31flavorscivic's Avatar
mine did something like that... Its a wiring issue. I just disconnected the little beeper at the top. It has something to do with a sensor from the door, and since I could never find it, I just unhooked it.
Old Nov 11, 2004 | 02:42 PM
i went and check the door again, took off the door panels on both side, disconnect 3 seperate plugs. did it on the other side too. now the door light won't come on. haha which is cooL. but the selt belt light is still beeping and flashing.. i also disconnected the plug on the bottom of the seat . . . on both seats . . still see the selt belt light . . . WHAT TO DO NOW? I just want that beep to go away and the flashing selt belt sign to not light on. . can i disconnect a wire for that to happen?
Old Nov 11, 2004 | 11:02 PM
Rednas's Avatar
Just pull the beeper out
Since it is not hooked up to any safety devices there is nothing lost by getting rid of it.
Old Nov 11, 2004 | 11:59 PM
civickiller's Avatar
Default Re: Selt belt light on beeping every 3 seconds .. . beep (Sand1)
that beeping sound is telling you that your door is open and your driving, but the beeping sound itself is coming from the seatbelt indicator probably telling you that your seatbelt isnt setup correct because your door is slightly open.
this happened to me the other day, my seatbelt just started beeping every 3 seconds, i opened and closed my door and it went away. i test it i started driving with my door open and it started doing it again
Old Nov 12, 2004 | 12:00 AM
FrankencrxBHAM's Avatar
take it 2 honda, if anything every goes wrong with the seatbelts honda will replace them for free, no questions asked.
Old Nov 16, 2004 | 06:42 PM
Default Re: Selt belt light on beeping every 3 seconds .. . beep (FrankencrxBHAM)
in my case it wasnt the seatbelt thing, it was the act of the door being opened. I took off the little thing by the rearview mirror and pulled the plug, replace.
Old Nov 16, 2004 | 06:49 PM
Rostr02's Avatar
Default Re: Selt belt light on beeping every 3 seconds .. . beep (31flavorscivic)
I pulled my seat belt alarm out best thing I have done thusfar. That little buzzer was a pain in the a**
traxxasx
Aug 1, 2011 05:23 PM
slowsinglecam
Classic Hondas
Oct 17, 2010 10:33 AM
slkrik72
Sep 24, 2010 07:13 PM
speedtrash2
Feb 14, 2007 07:01 AM
E-Rock
Oct 6, 2002 09:15 AM
