h22a check list
Old Nov 11, 2004 | 01:24 PM
92 CIVIC HATCH VX's Avatar
Default h22a check list
ok 92 civic vx
i have the swap with engine tranny ecu and harness lsd and shift linkage.
ok installed aready is a tein flex dampeners And maybe some energy suspension bushings.
ok i just installed a fluidyne radiator and fal fan.
next i was going to get mounts and axles
Maybe hasport or place racing
and drive shaft shor stage 3 axles.
<also since engine out i'm changine tining belt and fly wheel and clutch>
What else for the h22 prep and car prep. i have another car so i will be doing the swap myself.
Also any tools besides the basics. i have a crap load of tools already and i have the civic helms manual and i was going to get the prelude h22 helms manual and electrical if needed.
my uncle runs anarchy motors so i get swaps for cheap so i decided to go with the h22 complete swap he sent it ro me for 1000 shipped. obd1 version though out of the accord sir.
let me know on the list of what i might be missing.
Old Nov 11, 2004 | 02:12 PM
alleyezonme's Avatar
Default Re: h22a check list (92 CIVIC HATCH VX)
on my swap i just used the hoses from my civic and prelude and cut em up and made em work. so you should be good there. you might want to get some new spark plugs. its not a bad idea to slap on a new water pump too. if you use the 90-93 teg axles don't forget the prelude inners!! i had a lot of trouble with mine until i swapped the inners with the lude inners. change the oil, tranny fluid, and coolant b4 you crank her up. i don't know if you know this already but you can check your codes by looping a piece of speaker wire in the 2 port plug under the glovebox. there is a sticky at the top of this forum. ummmmmmmmmmm i think that is about it. ill keep thinking though. i did mine this past summer so it is still pretty fresh in my head. oh and the most important thing... HAVE FUN!!! its a blast! or a bitch. pick one!
good luck
Old Nov 11, 2004 | 03:19 PM
TriniTech's Avatar
go to h22a swap questions in this forum, there is everything you need to know
Shan243
Dec 2, 2013 06:51 AM
honda00az
Jul 2, 2012 09:20 PM
slo_hatch
Nov 9, 2007 01:53 AM
n0limitzracer916
Aug 12, 2006 10:22 PM
syndicate43
Mar 30, 2003 05:38 PM
