Need big help for tuning power fc
Old Nov 11, 2004 | 12:20 PM
JDM97R's Avatar
Default Need big help for tuning power fc
I have bought a power fc from a guy on this forum,it is already mapped but it came without the map sensor.
How can i know which map sensor he was using so i can use the ecu?
I already called him,power excel and the guy who built the engine,xs engineering but with no result.
I have the fc commander,can i check from it the voltage or something that can help to find which map was using?
What can i do ,i need a big help from you as usual guys,thanks
Old Nov 11, 2004 | 01:28 PM
b00stedbyFastrax's Avatar
Default Re: Need big help for tuning power fc (JDM97R)
just go into the settings menu and select PIM Volt. There you will see #1-#5 options ( not sure ,maybe #1-#4). anyway see which option is high-lighted. if #1 is high lighted, then it is the honda Map Sensor. If is the last option, it is a GM Map Sensor.
forryk
Oct 24, 2015 02:28 PM
vti444
Apr 14, 2005 08:01 PM
turbotypeR@SPEC
Jan 9, 2002 04:29 AM
joeyitr309
Oct 21, 2001 12:04 PM
