Suspension!????
Old Nov 11, 2004 | 10:48 AM
jannzyg22's Avatar
Default Which is the BEST Suspension!????
Sorry but I'm on sure of which suspension to get for 03 type -s, I want a nice ride. I was looking to see if anybody has the JIC's, Mugen, Tanabe or Tein, etc.
I live out in Boston and the street are all messed up, I want to be able to drive over a bump and not feel it. I had Tein SS in a 90 4dr civic w/ls motor and I loved the ride. I want to get something nice for my DC5. What do you guys recommand?? TIA
Modified by jannzyg22 at 9:09 AM 11/12/2004
Old Nov 11, 2004 | 12:21 PM
StageOne's Avatar
Default Re: Suspension!???? (jannzyg22)
If you want a suspension with a good ride and great balance, look at the A-Spec kit. The Mugen is also nice, but a bit firmer ride. Add a 22mm rear sway bar and the car will be nicely balance for the street.
Old Nov 11, 2004 | 12:34 PM
DC5ITR329's Avatar
Default Re: Suspension!???? (StageOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StageOne &raquo;</TD></TR><TR><TD CLASS="quote">If you want a suspension with a good ride and great balance, look at the A-Spec kit. The Mugen is also nice, but a bit firmer ride. Add a 22mm rear sway bar and the car will be nicely balance for the street. </TD></TR></TABLE>
I'm running a similar setup with ITR suspension and a ITR rear 22 mm sway. it's a good combo.
Old Nov 12, 2004 | 05:05 AM
jannzyg22's Avatar
anybody else recommand something else??
Old Nov 12, 2004 | 09:50 AM
Evoluti0n's Avatar
are the teins ss pretty good?
Old Nov 12, 2004 | 10:02 AM
rjsdxm's Avatar
Default Re: Suspension!???? (Evoluti0n)
the tien ss are awsome i have them the ride is great and you can hadle good as hell and they are very good for the track. they are deffinetly worth the money
Old Nov 12, 2004 | 10:23 AM
97 TYPE-R 312's Avatar
Default Re: Suspension!???? (rjsdxm)
Mugen is simple and easy, just bolt on and go, gives it a good ride height for daily driving and is comfortable, not rough at all. I am very satisfied with mine, as most others are as well.
-Victor
Old Nov 13, 2004 | 12:55 PM
03ephatch's Avatar
Default Re: Which is the BEST Suspension!???? (jannzyg22)
tanabe sustec pros type II should be out end of this month. ep3 omni's should be out around the same timeframe as well (for ep3 bubbas).
Old Nov 13, 2004 | 02:23 PM
JET_dC5's Avatar
Default Re: Which is the BEST Suspension!???? (03ephatch)
If you want the BEST suspension, FIGHTEX (by Todaracing) is the way to go, although they are geared towards track usage. You gotta be big ballin though, cuz a set for the dc5 will run you 3100.
http://www.todaracing.com/prod....html
Old Nov 13, 2004 | 02:28 PM
DC5ITR329's Avatar
Default Re: Which is the BEST Suspension!???? (JET_dC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JET_dC5 &raquo;</TD></TR><TR><TD CLASS="quote">If you want the BEST suspension, FIGHTEX (by Todaracing) is the way to go, although they are geared towards track usage. You gotta be big ballin though, cuz a set for the dc5 will run you 3100.
http://www.todaracing.com/prod....html</TD></TR></TABLE>
I don't think they are the best. they are good. but not the best.
Old Nov 13, 2004 | 02:36 PM
JET_dC4's Avatar
Default Re: Which is the BEST Suspension!???? (aznbo1626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznbo1626 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think they are the best. they are good. but not the best.</TD></TR></TABLE>
and of course you have track tested many cars on the fightex setup correct?
Old Nov 14, 2004 | 09:21 AM
KCANDJOJO's Avatar
i had the same problem.Dont get jic if u want to dump ur car more than 2 inches.I just ended up with springs until i save up for good ****.Omni are an option but i dont know if they r good.
Old Nov 14, 2004 | 06:28 PM
jannzyg22's Avatar
Default Re: Which is the BEST Suspension!???? (KCANDJOJO)
good comments, but anyboy else have better suspension on thier DC5???
yellowturbo
Honda Fit
Jan 31, 2008 10:27 AM
BoBoChan
28
Oct 30, 2005 07:13 AM
mugenkilla899
Feb 28, 2004 01:42 PM
VTECdTypS
33
Dec 7, 2003 02:12 PM
SD
Feb 7, 2002 04:06 PM
