External Coil, wiring question...
Old Nov 11, 2004 | 10:41 AM
JustinG60's Avatar
Default External Coil, wiring question...
i am hooking up an External coil on my teg, just a stock B18A but i have very very poor spark, so to my question... where do these wires go?
there is a solid blue wire and a black with yellow stripe that goes to stock. how do i wire the external coil up?
yes i searched and not one person talked about how to do this...
Old Nov 11, 2004 | 07:57 PM
mr.beeks's Avatar
Default Re: External Coil, wiring question... (JustinG60)
is really simple...
but make sure that you insulate the connection pretty
well or you will run into problems later on..
http://www.msdignitions.com
will give you all the instructions that you need
best advise try to buy msd products thru american dealers(cheaper)
import dealers overcharge a lot.
Old Nov 12, 2004 | 04:35 AM
JustinG60's Avatar
Default Re: External Coil, wiring question... (mr.beeks)
hmm i did not notice that the stock coil says which is positive and which is negative... but thanks for the info
Old Nov 12, 2004 | 05:40 AM
JimBlake's Avatar
On my '95, the coil 'A' terminal gets battery power, the 'B' terminal is wired to the ignitor. The ignitor closes B to ground, then opens it to fire the coil.
redlinez_r_us
May 28, 2010 12:05 PM
slowteg550
Jul 13, 2006 07:26 PM
951dc5
Nov 29, 2004 10:57 PM
PERFDIST
Jul 27, 2004 04:13 PM
insomniac791
Nov 25, 2003 06:48 PM
