Driving on a messed up engine?
Old Nov 11, 2004 | 10:36 AM
Shakes's Avatar
space cadet
Default Driving on a messed up engine?
Some of you know my delima already but for those that dont here it is.
I had a dent in my oil pan that i got from a friend. now stupid *** me figured ya know, its just a tiny little dent in the corner, it wont do anything. well, that just goes to show what greed, stupidity and impatients will do for you.
as i drove the car the oil light would pop on once in a while but go away right away. i drove the car like this for about 200 miles before pulling the oil pan off to pound out the dent, thinking that was the problem.
when i removed the pan, this is what i saw
this is 200 mile old Mobil 1 Synthetic 5w30, filled with SILVERISH colored shavings. now people that know what they are doing can tell better, but MHO is cylinder wall / piston pieces from scarring due to lack of oil.
if you look at my fingertip you can see a chunk of aluminum. it was about 1mm thick with ridges on the end of one side. my guess is thats a piece of piston.
so the engine is most likely toasted, i am supposed to move across country in one month and i dont have a spare engine. im going to just ship it out to san diego and fix it there, but here lies the question...
how long will an engine with this kind of damage going to last? can i still drive it to and from work or no? i know you cant make a real determination without pulling the engine apart but still. i know some of you had piston and wall scarring and drove on it for a while.
TIA
Old Nov 11, 2004 | 10:40 AM
hoehouseworker's Avatar
Default Re: Driving on a messed up engine? (Shakes)
that sucks. good luck.
Old Nov 11, 2004 | 10:47 AM
v4lu3s's Avatar
RTFM
it is more liekly pieces of your bearings, and if you continue to drive it you may spin a bearing and do damamge to your crank shaft.
Old Nov 11, 2004 | 10:49 AM
Shakes's Avatar
space cadet
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">it is more liekly pieces of your bearings, and if you continue to drive it you may spin a bearing and do damamge to your crank shaft.</TD></TR></TABLE>
i did run a magnet through the oil when i drained it and nothing was picked up. also i was told that bearing shavings are gold, not silver... truth to this?
Old Nov 11, 2004 | 11:14 AM
BrokeLude's Avatar
Default Re: (Shakes)
That'll learn ya to change your blinker fluid more often...
PirateMcFred's Avatar
Time for an F23 bottom end swap?
But really I would not drive much on it. If it is a piston then you might have to sleeve to save the cylinders if you continue driving. The particles will go thoughout your system and get in the bearng sand cam journals and if there are enough particles it can block oil passages (very bad).
Pirate
Old Nov 11, 2004 | 11:17 AM
Shakes's Avatar
space cadet
Default Re: (BrokeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">That'll learn ya to change your blinker fluid more often...</TD></TR></TABLE>
not even close to funny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Time for an F23 bottom end swap?
Pirate</TD></TR></TABLE>
Old Nov 11, 2004 | 11:20 AM
LudeyKrus's Avatar
Well IIRC bearings contain bronze, but will usually look silver and sometimes bronze. They are magnetic though.
I can guarantee you that a good deal of the shavings are from your bearings.
Assuming you drove it w/ the dent up to the oil pickup tube, and that it is not acting funny or making funny noises yet, it should last for a little while longer. The bearings will probably spin first, so take it very easy on the car and drive it till you can get a new motor in line.
Oh, keep some cash back in case the motor pops before you are ready and you have to tow it home
Old Nov 11, 2004 | 12:05 PM
A compression test will tell you if it is your rings/pistons. My H23 had lots of magnetic particles. so it may just be your pistons. I still recommend against driving it in the mean time.
Pirate
Old Nov 11, 2004 | 12:21 PM
preludeez's Avatar
Default Re: (PirateMcFred)
damn doug, sorry to hear about this man... if there is anything i can help you out with while you're still here, let me know.
nick
Old Nov 11, 2004 | 12:22 PM
Shakes's Avatar
space cadet
Default Re: (preludeez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeez &raquo;</TD></TR><TR><TD CLASS="quote">damn doug, sorry to hear about this man... if there is anything i can help you out with while you're still here, let me know.
nick</TD></TR></TABLE>
thanks for the offer, but i think right now every thing is so fucked up that it wouldnt even matter if the engine blew up on me or not.
Old Nov 11, 2004 | 12:29 PM
98TypeSH's Avatar
im sorry to hear that too bro. whats the next step for the lude? sell the shell ?
that ****** sucks man. Im doin everything i can to fix my code 9, short of replacing the dizzy. i dont got one to swap right now.
Old Nov 11, 2004 | 01:07 PM
H23vtecEG's Avatar
Default Re: (98TypeSH)
well if you want a quick and cheap fix. replace all the bearings and call it a day, this is of course if you havent done any damage to the cranck. so rip it apart and asap
Old Nov 11, 2004 | 01:11 PM
Shakes's Avatar
space cadet
Default Re: (H23vtecEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG &raquo;</TD></TR><TR><TD CLASS="quote">well if you want a quick and cheap fix. replace all the bearings and call it a day, this is of course if you havent done any damage to the cranck. so rip it apart and asap </TD></TR></TABLE>
yes, let me get right on that.
i really wish that i could rip it apart right now, but at the moment i dont even have the ability to finish what i started let alone start another project.
Old Nov 11, 2004 | 02:17 PM
2kflamedlude's Avatar
Yep we are both fucked.
Old Nov 11, 2004 | 02:18 PM
Shakes's Avatar
space cadet
Default Re: (2kflamedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kflamedlude &raquo;</TD></TR><TR><TD CLASS="quote">Yep we are both fucked.</TD></TR></TABLE>
you got nicer rims though
Old Nov 11, 2004 | 02:26 PM
AndyD's Avatar
Doug,
I am not sure how much this will help you out but if no one buys my H23 longblock within the next few weeks, and you need a motor to help you get your car to wherever you are going, you can swap my motor into your car for the time being. Besides, most of the people who have inquired about my motor have been on the west coast or some other part of the country. Once you are done with it, and pull it out, then I can advertise it for sale at that point.
I am in Maryland so we can meet up anyway.
EDIT: Oops, I don't know what I was thinking. I forgot you had a 5th gen Type SH.
Anyway, if it can help you out, let me know.
Nikoli's Avatar
dam man that sucks, i know how you feel. i have had non stop issues with my car as well
good luck
Old Nov 11, 2004 | 02:49 PM
Shakes's Avatar
space cadet
Default Re: (AndyD)
nah, i can just push the hooker into the moving van or whatever ends up being used. i do greatly appreciate the offer though.
Old Nov 12, 2004 | 07:06 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">i did run a magnet through the oil when i drained it and nothing was picked up. also i was told that bearing shavings are gold, not silver... truth to this?</TD></TR></TABLE>
last engine i ahd built by a machine shop they put the worng bearings in ad we ended up with lots of shavings that looked identical to the ones you have, mostly it was the outer layer of the bearing for us, and i never checked to see if they were magnetic, sicne we pulled the engine right away, had to get all new bearings and either turn the crank or get a new cranks ince it was torn up.
ramz7887
17
Mar 20, 2007 12:07 PM
thegeorge613
Jul 31, 2006 05:02 PM
rival12
Sep 20, 2005 04:29 PM
EF7
Aug 5, 2003 12:44 AM
EGh22aEG
Apr 15, 2002 07:00 PM
