Auto to Manual Clutch Pedal
Old Dec 25, 2001 | 02:32 PM
SiViK-R's Avatar
Default Auto to Manual Clutch Pedal
Hey whats up honda-techs...im going from auto to manual tranny...as i was installing the new clutch pedal i seen two switches with wires on it...do i need to wire those two switches up??...if i do i need to find out where do i wire these switches wires since my car was auto before...and also is it okay for me to use my original wiring harness??
Old Dec 25, 2001 | 08:05 PM
salbaje's Avatar
Default Re: Auto to Manual Clutch Pedal (SiViKbOi)
those 2 swithches are probably for the sensor that starts your car when you push your clutch down. you dont have to wire that and you can start your car without pushing clutch down. yes you can use your stock harness. hit me up if you get lost i do plenty of auto to manual swap salbaje1@attbi.com
Old Dec 25, 2001 | 08:57 PM
c-notecoupe's Avatar
one is the clutch start switch, screw that i just jumped out mine so i don't need to press the clutch to start the car and the other switch is probably a cruise control cutoff. but i could be wrong.
JokerX-1.6T
Jun 8, 2007 05:08 PM
mmmtrbolude93
Jun 29, 2006 11:36 AM
Specail Ed
Mar 6, 2003 02:13 PM
jdm92accord
Mar 27, 2002 04:19 PM
