N/A Nonvtecs, I need your help!
Old Nov 11, 2004 | 09:42 AM
hybrid_vtec's Avatar
Default N/A Nonvtecs, I need your help!
The guy that created allmotorhonda.com is updating his website! For those of you that have Crower Cams knows that the Crower website cam specs are wrong compared to the spec sheet that comes with the cams. I have already gave him the specs for the 62404-2! So we need specs for all aftermarket cams for B18A/B and B20's:
Crower B18A/B, B20
62401, 62402, 62403, 62405, and 62405A(ireally would like to see the spec on the 405 cams)
Also post up specs to Crane Cams(all grinds), Colt cams, Exospeed, JG Engine Dynamics, and any others I missed!
Post your specs here or post them to this thread:
https://honda-tech.com/zerothread?id=1050835
Old Nov 11, 2004 | 12:11 PM
ExospeedAMcrx's Avatar
Default Re: N/A Nonvtecs, I need your help! (hybrid_vtec)
we had posted our specs awhile back... i'll get them again and send it to you guys
LS909 Dur @.010 268/254 Lift 400/388
* does not require valvetrain.
* powerband is 3000-7600 RPM
Race LS Dur @.010 268/268 Lift 400/400
* Requires valvetrain upgrade if taking it past stock Rev limit.
* powerband is 3000-8000 RPM
Stage 4 cams available for serious racers.
Modified by exospeedAMcrx at 4:11 PM 11/11/2004
Old Nov 11, 2004 | 12:21 PM
arw321's Avatar
Default Re: N/A Nonvtecs, I need your help! (exospeedAMcrx)
Colt LS Race Cams:
INTAKE: duration = 278, lift = .432
EXHAUST: duration = 278, lift = .423
Old Nov 11, 2004 | 04:49 PM
Default Re: N/A Nonvtecs, I need your help! (arw321)
thanks guys! keep em coming!
Old Nov 11, 2004 | 05:29 PM
Crisgo's Avatar
gOOD info
Old Nov 11, 2004 | 07:04 PM
Default Re: N/A Nonvtecs, I need your help! (Crisgo)
Need the specs for the cams used by the few that go all out on LS's and B20's!
Crower 405's
Crower 405A's
Crane #18
Crane #20
Also I n=know there are plenty of you that use other cams too! Pitch in some info! Thanx!
Old Nov 11, 2004 | 11:13 PM
vhd's Avatar
vhd
ill help out with the crane cams, since i am probably one of the few running crane cams....
Crane 101-0018
intake:
-lift @ cam = .250"
-lift @ valve = .453"
-advertised duration = 254 degrees
-duration @ .050" = 226 degrees-
-valve opens @ 12 degrees BTDC
-valve closes @ 34 degrees ABDC
-lobe seperation = 104
-lift @ TDC overlap = .096"
-lash = .004" cold
exhaust:
-lift @ cam = .250"
-valve opens @ 40 degrees BBDC
-valve closes @ 6 degrees ATDC
-lift @ TDC overlap = .071"
-lash = .008" cold
for the crane 101-0020
-advetised duration = 262 degrees
-duration @ .050" = 234
-lobe seperation = 108
-valve lift = .472
this is for both intake and exhaust
Old Nov 12, 2004 | 01:02 AM
nonvtecallmotor's Avatar
Default Re: N/A Nonvtecs, I need your help! (vhd)
Crower 405's
Intake..... 502 lift @ 252 duration @ .050"
Exhaust ...502 lift @ 252 duration @ .050"
Crower 405a's
Intake..... 476 lift @ 230 duration @ .050"
Exhaust... 467 lift @ 222 duration @ .050"
Old Nov 12, 2004 | 06:16 AM
hype r 555's Avatar
Default Re: N/A Nonvtecs, I need your help! (nonvtecallmotor)
CRANE 101-0012
in. dur. 232 lift .400
ex. dur. 250 lift .388
109 lobe sep.
Old Nov 12, 2004 | 10:10 AM
Default Re: N/A Nonvtecs, I need your help! (lsed-eg)
thanks guys keep them coming!
Now we need some specs on the 403's!
Old Nov 13, 2004 | 12:43 AM
BUMP!
Old Nov 14, 2004 | 06:48 PM
bump!
Old Nov 18, 2004 | 09:33 AM
bump for more info!
Old Nov 18, 2004 | 04:31 PM
AllMotorMark's Avatar
thanks guys, i will put it up as soon as i can
Old Nov 18, 2004 | 09:35 PM
Default Re: N/A Nonvtecs, I need your help! (AllMotorMark)
Need specs for:
Crower 62403's
Crane #14's
Crane #16's
Modified by hybrid_vtec at 10:56 PM 11/18/2004
Old Nov 18, 2004 | 10:39 PM
White98LS's Avatar
tage 2 - Street/Strip package. MOST POPULAR profile. Requires 84162 kit. 1000 to 8000+ rpm (15-18 hp).
Intake duration 243
Exhaust duration 246
Intake lift .423
Exhaust lift .409
DAMMIT I compiled a list of specs on every B18A/B cam in existence a couple years ago but it's on my other computer at home... I'll try to find it this weekend.
Old Nov 19, 2004 | 11:42 AM
Default Re: N/A Nonvtecs, I need your help! (White98LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White98LS &raquo;</TD></TR><TR><TD CLASS="quote">
DAMMIT I compiled a list of specs on every B18A/B cam in existence a couple years ago but it's on my other computer at home... I'll try to find it this weekend.</TD></TR></TABLE>
Cool **** thanks!
Old Nov 28, 2004 | 02:04 PM
these are up now, thanks guys
Old Nov 28, 2004 | 02:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorMark &raquo;</TD></TR><TR><TD CLASS="quote">these are up now, thanks guys </TD></TR></TABLE>
I have a big list I will post up for you!
Old Nov 28, 2004 | 10:53 PM
White98LS's Avatar
Cams/Part # Dur. int/exh Max lift Notes
Stock B18B 220/222 .395/.380"
Crower 62401 224/226 .395/.380 Stock replacement
Crower 62402 233/245 .414/.399 Mild but noticeable gain
Crower 62403 243/246 .423/.409 Good for street
Crower 62404 249/251 .446/.432 Pwr past stock redline
Crower 62405 287/287 .502/.502 Insane, not for street!
Crower 62402T 235/235 .469/.469 For turbo applications
Crower 62405A 280/274 .476/.467 Crazy drag-only profile
Crane Stage 1 257/263 .400/.388 Mid-range and high-end
Crane Stage 2 261/267 .400/.388 + high / - mid than St. 1
Crane Stage 3 261/259 .400/.388 For turbo applications
Crane Stage 4 274/274 .433/.433 Mainly high-end power
Crane Stage 5 282/282 .453/.453 Big-time high-end
Crane Stage 6 290/290 .472/.472 Definitely race-only!
Gude AIC S05 228/228 .410/.410 Minor mid/hi-rpm gains
Gude AIC S06 236/236 .431/.431 Mainly high-rpm gains.
Gude AIC S07 264/264 .412/.412 High-end, good w/N20
Gude AIC S08 236/236 .410/.410 For turbo applications
Web Cam 35-000 228/228 .395/.390 Slight gains all around
Web Cam 35-220 242/242 .395/.395 Mid/high-rpm gains
Web Cam 35-270 250/250 .410/.405 Mainly high-rpm gains
*Note: Crower and Crane cams are made from scratch of billet steel, Gude and Web Cam cams are regrinds.
Dug this up from my old computer this weekend. You can thank me later.
Old Nov 29, 2004 | 03:21 AM
Dug this up from my old computer this weekend. You can thank me later. </TD></TR></TABLE>
fukb20
Dec 6, 2012 10:27 AM
jdmcivic2fast
Feb 4, 2012 08:38 PM
ilikejesus
Apr 26, 2007 08:07 PM
MrParks
Feb 19, 2004 04:17 AM
