Compression Test Results
Look at my thread below on the Total Seal rings, I have 240 across except for cylinder 3 which is 220. Just built my motor too
, do you happen to smell any while you frive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">compression #'s are rather close to each other, but you might try a different oil first.</TD></TR></TABLE>
I am using Motul 8100 5w40 now, what other oil would you suggest?
I am running a test pipe, so I can definitely smell it.
i have tried 20w50 to 15w50 to 10w30 to 5w30, different brands, Pennzoil, Mobil1, Amsoil, Royal Purple, Lucas oil additives you name it i've tried it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Have you tired the recommend 5-30? If so what was the results?</TD></TR></TABLE>
I tried 10W40 300V and it still the same. May be I should try different brand or something cheaper.
I did a leakdown last month already and it was like 5-7% in 3 cylinders and one cylinder was 20%. And I think that the same cylinder that has 215 compression.
The air is coming from the oil cap on the 20% one, and I can't hear any air leaking for the other 3 cylinders.
I see that there are three people here asking questions on One persons post, not that I have a hard time reading but maybe it would be beneficial to make your own threads?
Evereyone has slightly different setups and not one answer is for all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Maybe... taking a shot here...
Valve seals could be bad.</TD></TR></TABLE>
I thought it is the piston ring if the air is coming out of the oil cap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 TYPE R »</TD></TR><TR><TD CLASS="quote">i have a brand new from acura r motor and it has 500 miles on it my compression is 210 in all four i use mobil 1 5-30, is that low or ok guys.</TD></TR></TABLE>
The raw number can vary a lot. What you're looking for in a compression test is a variance between the cylinders. Since you're solid across the board, you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Look slike your burning regardless of brand or weight, You might want to try a leak down test before taking it apart.
I agree....but what the hell made you wanna check your compression in the first place? Is it running shitty or just using some oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">I see that there are three people here asking questions on One persons post, not that I have a hard time reading but maybe it would be beneficial to make your own threads?
Evereyone has slightly different setups and not one answer is for all.</TD></TR></TABLE>
Not trying to hijack anyones thread its just that I have the same exact problem with my motor as well. Wanted to see what he's doing about it.
Drinker
