It's wrench time!!!
Old Nov 10, 2004 | 11:20 PM
DualCamDan's Avatar
Default It's wrench time!!!
well i just finished working on my car this afternoon and figured i'd go play around a bit!!! well i FU%^ED it up!!! it's all crazy boggy and i melted the tip of my plug! yes, i was spraying! STUPID ME!!! how bad can it really be? what should i do? i have a y7 motor w/ a y8 IM, B18 TB.... is it worth trying to fix it? the motor only has like 57k on it....
what steps should i take to find out how bad or whats wrong???
it looks melted! i think it's all there... but i'm not for sure...
Old Nov 10, 2004 | 11:30 PM
Magick211's Avatar
Default Re: It's wrench time!!! (whitey_4g)
Id start out by running a compression test
Old Nov 11, 2004 | 12:02 AM
Ray-mond's Avatar
Default Re: It's wrench time!!! (Magick211)
if thats your spark plug you have a mean ******* gap. on it or the tip of the spark plug is missing i think you have your gap set at 75. plus not good that well make you bogg and back fire. if your juicing go with a small gap. on your plug.and get some cold ones.
Old Nov 11, 2004 | 12:20 AM
DualCamDan's Avatar
Default Re: It's wrench time!!! (89hbb16a3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbb16a3 &raquo;</TD></TR><TR><TD CLASS="quote">if thats your spark plug you have a mean ******* gap. on it or the tip of the spark plug is missing i think you have your gap set at 75. plus not good that well make you bogg and back fire. if your juicing go with a small gap. on your plug.and get some cold ones.
my plugs are 1 step colder NGK's w/ a .38 gap on them! the tip is all melted. i changed them and it still runs really bad!!!
Old Nov 11, 2004 | 09:37 AM
green91's Avatar
probably denotated that bitch to hell, run a compression test
Old Nov 11, 2004 | 02:05 PM
RapeV-8's Avatar
just gave me the car and i ll finish it with a 150 shot!!haha
Old Nov 11, 2004 | 03:00 PM
90LSpimpin's Avatar
Default Re: (igotcrx)
C'mon man! Already???!!! You just HAD to spray didnt you. Oh well, hopefully its not too serious. Yea if you melted a plug like that its most likely detonation. And it can either be a small problem, or a very huge one as far as things bein wrong...not really any gray area....
triskpin
Aug 13, 2014 05:35 AM
turboedsupe
Feb 17, 2009 06:25 AM
HypnotikEFX
May 2, 2005 09:11 PM
dohcvtecCx94
Mar 12, 2005 07:04 PM
Cosworth
Oct 19, 2003 02:35 PM
