How to wire JDM Foglights?
Old Dec 25, 2001 | 11:40 AM
SKRacer's Avatar
Default How to wire JDM Foglights?
Just got a JDM foglight switch and just wanted to know if anyone knows all what I need to wire up the foglights on the jdm front end ie what kind of bulbs to use etc. Thanks.
Old Dec 25, 2001 | 01:33 PM
Mike M's Avatar
Founding Member
Default Re: How to wire JDM Foglights? (Fuzznuts)
Ok since this question is asked So Many times, here is a quick How to https://honda-tech.com/zerothread?id=105247
Merry Christmas
Old Dec 25, 2001 | 01:39 PM
TypeR 599's Avatar
Default Re: How to wire JDM Foglights? (TypeRmsm)
hey mike, can you tell me how to get my hazard lights to work?
are my corner lights(amber ones) suppose to be on when my parking light is on? only the middle lights(the ones between the fog and the projectors) are on when the parking lights are on. tia
Old Dec 25, 2001 | 01:42 PM
Mike M's Avatar
Founding Member
Default Re: How to wire JDM Foglights? (type R 599)
The lights inside with the High beams and Sidemarkers (On fenders) should be on with the parking lights, Shouldnt flash. The Turn signals (outermost lights on the headlights will flash when turn signal or hazards are on. If not someone wired it wrong.
Old Dec 25, 2001 | 01:47 PM
TypeR 599's Avatar
the lights inside with the high beams dont flash/blink. the fender lights are not on when the parking lights are on. and my hazards dont work . turn signals (the outer part of the house) blink with the side markers.
Old Dec 25, 2001 | 01:52 PM
Mike M's Avatar
Founding Member
Their not supposed to
Leave it if you dont mind it, but as I said it should be on with the parking lights and shouldnt flash
But they dont blink when the hazards are on?
Sounds like it just wasnt wired up properly
Old Dec 25, 2001 | 02:00 PM
Double 06's Avatar
New User
i got the schematic and i appreciate it, but i thought the integras were prewired for fogs, if that isn't the case is why i need to use a cruise control harness? can someone please clarify this, i really didnt' want to run alot of wires through the dash and engine bay
ohh well, i'll let a shop do it probably.
Old Dec 25, 2001 | 02:14 PM
Mike M's Avatar
Founding Member
Default Re: How to wire JDM Foglights? (Double 06)
You guys have to read through the whole thing
You dont have to run much wire at all, Only from the fusebox to the switch and relay, which are all within a few inches from each other, You can bolt the relay near the fusebox. There is already a wire running through the firewall from the interior to the engine bay, just connect the inside end to the relay and the outside to the foglights. As far as the amount of wire being used inside the car if you add it all up its only about 12-18" Total.
Its not too hard at all Take your time and keep it neat, use some Tubing etc it will look stock.
Closing this one, Please add any questions in the other post
Thanks
racehesh
11
Jul 15, 2007 07:36 PM
99delsol
Aug 24, 2006 09:57 PM
NorthernXposure
Aug 11, 2006 02:11 AM
SiSpopu
Acura TL, RL & ZDX
Jul 22, 2006 02:46 PM
BlingBlingCivic
10
Sep 7, 2001 12:42 PM
