My Civic Ball joint (buffalo)
Old Nov 10, 2004 | 08:40 PM
scsheong's Avatar
Default My Civic Ball joint (buffalo)
Just wanna check out how much does it cost to fix a ball joint? I dun wanna get conned by those mechanics....Anyway if there's some1 help me out..tat would be great
Old Nov 11, 2004 | 05:35 AM
EE_Chris's Avatar
Default Re: My Civic Ball joint (scsheong)
Upper ball joints aren't 'replaceable' - you have to replace the whole upper control arm because the ball joint is pinned in. UCA ~$50-60 (OEM).
Lower ball joints can be replaced. Parts are about $30 (OEM) but to replace it, the whole knuckle needs to come out so that the ball joint can be pressed in/out.
I'm GUESSING that 'the book' states about 2-3 hours for either repair - so figure $40-60/hour and you could be looking at a sub-$200 repair cost.
No chance of you being able to do this yourself/friends?
Old Nov 11, 2004 | 06:04 AM
monicle's Avatar
If youre looking for uppser Ive got the entire arms from a 2000 civic that will work for you.
Old Nov 11, 2004 | 06:44 AM
klungemonger's Avatar
96-00 ball joints aren't available seperate from the whole upper arm (same with later accords Im sure) but earlier models you can get the joints pressed out and new ones pressed in. Becuase Progress upper camber kits for DC and EG are just offset-studded ball joints using the stock arms.
What year/model do you have?
whyS0serious
Suspension & Brakes
Apr 17, 2018 12:45 PM
skhell
May 11, 2016 09:57 PM
Kevs02Accord
Nov 8, 2011 04:04 AM
G2_Fella
24
Jun 16, 2009 03:20 PM
Powered by VTEC
Jan 1, 2008 10:51 AM
