window problem ... wont roll up
Old 11-11-2004, 06:43 AM
hondahatch741's Avatar
Default window problem ... wont roll up
i have a 94 dx and my drivers side window wont roll up becuase it itsnt aligned... it rubs against the stripping and the little plastic peice next to the window.. i need help cuz i cant roll down the window.. i need to know what i need to replace. thanks
Old 11-11-2004, 06:50 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: window problem ... wont roll up (hondahatch741)
Buy a new power window regulator. Chances are, yours is now bent, and you will never get it aligned correctly again.
Old 11-11-2004, 06:51 AM
klungemonger's Avatar
You may or may not even have to replace anything...get the door panel off and check out the window regulator and stuff to make sure it's not just a loose bolt or misalignment of the glass in the track.
It's a DX, I don't think he has power windows...
Old 11-11-2004, 06:55 AM
SIowner's Avatar
Default Re: (klungemonger)
try checking to see if its a blown fuse, cause i had the same exact problem and it turned out to be a blown right side door fuse
Old 11-11-2004, 06:56 AM
Ya@inlinePRO's Avatar
does the 94dx have power windows?
pop off the door panels, and make sure its aligned right.
taimysho0
16
11-11-2008 05:25 PM
4Dinsaneb16
03-20-2007 01:30 PM
OriginalFive
Honda S2000
05-03-2006 10:11 AM
H22aInside
09-19-2002 11:12 AM
Quick Reply: window problem ... wont roll up
