195/50...will this hurt the R's performance????
Old Dec 25, 2001 | 11:28 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default 195/50...will this hurt the R's performance????
TireRack is selling SO-3s in this size for only $78. This is an awesome deal, but I don't want to waste any money. Are there any performance drawbacks from not getting them in 205/50 size. Thanks in advance.
Old Dec 25, 2001 | 12:25 PM
Dirty GS-R's Avatar
New User
Default Re: 195/50...will this hurt the R's performance???? (ActiveAero)
195/50's wont hurt performance from the stock 195/55's but obviously the 205's will give you more grip and better handling.
Old Dec 25, 2001 | 12:31 PM
aklucsarits's Avatar
New User
195/50 will help performance over 195/55. With 195/50, you will get better acceleration due to the smaller overall wheel/tire diameter. The downside is that your speedometer will be thrown off a little. You will read a little lower speed than you are actually going... I'm too drunk to remember the formula to calculate the amount it will be off at the moment...
Andrew
Old Dec 25, 2001 | 12:54 PM
SpeedRacer00-667's Avatar
Default Re: 195/50...will this hurt the R's performance???? (aklucsarits)
i like my 195/50/15 better than when i had 205/50/15. it just feels better
Old Dec 25, 2001 | 01:46 PM
type r 01-1063's Avatar
are they s-03's any better than the re010's?
type r 01-1063 - woohooo!!!! my 100th post
[Modified by type r 01-1063, 10:47 PM 12/25/2001]
Old Dec 25, 2001 | 02:32 PM
6ghatch's Avatar
195-50-15 will change you final drive ratio just a bit for the better, but if you ask me I'd stick with 205-50-15 or 195-55-15. And another point is that the 195-55-15's have a slightly larger foot print (over 195-50-15) due to its large rolling diameter, width is not the only thing to consider.
Old Dec 25, 2001 | 02:44 PM
CivicV10@18000rpm's Avatar
Actually its the other way around. Since the overall diameter is smaller, the smaller diameter tire/wheel combo will be turning faster than stock diameters. As a result, the speedo will read faster speeds on the smaller diameter wheel than the stock ones at a given actual speed.
Andrew
Old Dec 25, 2001 | 07:06 PM
travis's Avatar
Default Re: 195/50...will this hurt the R's performance???? (CivicV10@18000rpm)
I had a set of yok intermediates in 195/50/15 for a while, and they were just fine. They spin fast, so you'll be a few MPH high on the spedo, but I was happy with them.
TOO MUCH TORQUE
Nov 15, 2008 12:59 PM
kupras
Aug 25, 2005 06:38 PM
mrmonk
Feb 11, 2004 08:26 AM
1stealthls
Feb 7, 2003 11:22 AM
boywonda
11
Oct 29, 2002 08:17 PM
