41 Primary oxygen sensor heater
Old Nov 10, 2004 | 06:55 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default 41 Primary oxygen sensor heater
explain this. i have a 94 civic hb vx with a d16y8 comeplete swap. the motor is still obd2 and the car is running obd1 with a p28 ecu. i wired in the 4 wire o2 today and i just have a code throwing 41?
Old Nov 10, 2004 | 07:41 PM
thisisntjared's Avatar
Default Re: 41 Primary oxygen sensor heater (NJHatch)
aight bro check it, its like this. i tried telling you tonight but for some reason or another you got kicked off.
since its just code 41:
the 2 black wires from your new o2 sensor go to (1)A6 on the ecu while the other (2)splices into either a25 or b1 on the ecu
there are other ways of wiring it to where the harnesses meet at the shock tower, but i cant explain that unless we are infront of the car or the manual. which i have and you do not
DelSolDon
Jun 5, 2011 06:06 AM
vtec25
Mar 14, 2006 02:39 AM
92eg6
Sep 10, 2005 08:00 PM
kapoosh valve
23
Jul 1, 2005 09:02 PM
DreamSpeed
Jan 13, 2002 11:29 PM
