Need motor mount help on 89' civic
Old Nov 10, 2004 | 06:42 PM
Rallysport91's Avatar
Default Need motor mount help on 89' civic
I am new to honda's and I need to see if you guys can help me out.
I just bought an 89' honda civic, 1.5 automatic, with 55,000 miles on it. The only thing wrong with it was the motor seemed to have a bad motor mount. It would sort of clunk when it shifted gears. I Changed the mounts, and it's better but it still clunks a little when it revs up. I noticed that the back motor mount by the firewall seems to move quite a bit and I think it is making this motor move to much. Do they sell any sort of aftermarket mount for these cars. I have seen some people talking about motor mount inserts, I am not familiar with these at all and if someone can help me out with this I would love it!
Old Nov 11, 2004 | 03:30 PM
dr_latino999's Avatar
Default Re: Need motor mount help on 89' civic (Rallysport91)
What I have and am very happy with -
http://jimfab.com/motor/motor.html
$75 shipped for front and rear.
Old Nov 11, 2004 | 03:33 PM
APEX CRX's Avatar
only 2 mounts that control engine torque is the front trans and rear mount. If you can actually see the rear mount move even after you replaced it it can't be in the mount itself. Are you sure its bolted up completely?
Old Nov 11, 2004 | 03:38 PM
Default Re: Need motor mount help on 89' civic (APEX CRX)
Yeah i am pretty sure it is bolted down good. The metal part of the mount is firm,but the rubber just moves quite a bit. I was thinking of trying the motor mount inserts. Have any of you tried them?
Old Nov 11, 2004 | 04:03 PM
APEX CRX's Avatar
yeah I had the prothane ones in my old D16a setup and it helped alot. Dis you replace the mounts with new ones or used ones?
Old Nov 11, 2004 | 06:00 PM
sohcd16's Avatar
i have mount inserts on my crx and it helps movement alot, but you get pretty bad vibration in the car
Old Nov 12, 2004 | 11:07 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
your mild mannered daily driver will pointlessly become a rattletrap with poly mounts.
go to a hardware store and buy a tube of pulyurethane contruction adhesive. one at a time take off your mounts, set tape or saran wrap on the opposite side so it doesnt leak out,, and fill em up. when it hardens, your mounts will be firmer, but not like the typical aftermarket rocks. save yourself a couple hundred.
Old Nov 13, 2004 | 09:34 AM
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">your mild mannered daily driver will pointlessly become a rattletrap with poly mounts.
go to a hardware store and buy a tube of pulyurethane contruction adhesive. one at a time take off your mounts, set tape or saran wrap on the opposite side so it doesnt leak out,, and fill em up. when it hardens, your mounts will be firmer, but not like the typical aftermarket rocks. save yourself a couple hundred.</TD></TR></TABLE>
That can't help you though if that mount isn't broken and where do you get the couple hundred price tag? Mount inserts are $25 for front and rear and NEW mounts from JimFab are $75. So either way, I have yet to see any figure over 100.
shady8277
Jan 7, 2013 07:00 AM
Si Speed
Oct 6, 2007 03:03 PM
onyx00
Sep 24, 2004 01:00 PM
Train
Jun 12, 2003 10:28 PM
TeamFlip02
Sep 12, 2002 07:49 AM
