JDM Conversion (HID vs. Non-HID)
Old Dec 25, 2001 | 09:35 AM
AllMotorITR's Avatar
New User
Default JDM Conversion (HID vs. Non-HID)
I was just wondering what the differences between the two kits were besides the fact that one comes with HID and the other does not... How bright are the JDM HIDs? Are they really worth the extra cost?
Old Dec 25, 2001 | 09:38 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: JDM Conversion (1 FAST R)
Isn't it like an extra 1000 bucks?
Old Dec 25, 2001 | 09:45 AM
Mike M's Avatar
Founding Member
Default Re: JDM Conversion (Ross)
$1200 more
Old Dec 25, 2001 | 09:47 AM
New User
Default Re: JDM Conversion (TypeRmsm)
How bright are they in comparison to the Philips kits? 4300, 6000k? I hear they have a greenish tint to them.....
Old Dec 25, 2001 | 09:55 AM
Rboosted717's Avatar
here's a picture to help you:
left is OEM JDM HID's
right is JDM w/Philips HID kit
Old Dec 25, 2001 | 10:04 AM
slowpoketeg's Avatar
Default Re: JDM Conversion (Rboosted717)
the oem jdm clowns the philips.
Old Dec 25, 2001 | 10:09 AM
New User
Default Re: JDM Conversion (slowpoketeg)
Why do you say it clowns? Why not just get a 6000k Philips kit for $500, and use the other $500-700 for other mods.
not really. Color wise the Philips to me looks better. However for projection reasons, the OEM will always be better.
Its really up to you if you want the color look or the performance aspect of having OEM HID's.
With OEM HID's you get a crazy cutoff pattern from the special headlight housings. The Philips kit can do the same, however you need to have the OEM HID housings. Basically headlight housings that are designed for HID's will always be better in projection then just normal projector headlights. However if color is the issue, both look nice. The OEM's have a green/blue look, the Philips have a purple/blue look. So its up to you.
Old Dec 25, 2001 | 10:12 AM
exactly. The 6000k will give you even more of a blue/white look. A look that no other HID or OEM HID headlights will give. Basically the main advantage of getting OEM HID's is for the cuttoff beam that you get with OEM HID's. If you want to see the difference (which I would recommend since HID's either way are tons of money) come by and I'll show you mine on the road vs. a HID kit on just projectors.
Old Dec 25, 2001 | 10:44 AM
BlazinITR's Avatar
New User
What do you mean by Cut off beam? I was thinking about just buying the Phillips 6000 for my OEM Projector head light for my Integra. Is the light beam in the NON-HIDs head lights scattered compared to the HIDs head lights?
Old Dec 25, 2001 | 10:46 AM
New User
Default Re: JDM Conversion (Blazin ITR)
Yeah, I don't understand what you mean by cut-off beam either... What is it?
Old Dec 25, 2001 | 10:52 AM
the cuttoff beam is the beam the projectors emit. On stock projectors w/HID's you have a nice cut off beam up close. But from a far distance that beam looses its sharpness. Also the range that projectors emit is semi-small. Range as in the light shooting from the left side of the car to the right side of the car with a sharp cut off beam.
Where as OEM HID's emit a sharp cuttoff beam from close or far away. Also their range from left to right is greater by no compairison.
Its kinda hard to explain. My best suggestion is go ride in a car with projectors with a HID kit on them. Then go ride in a S2000, X5, Audi, etc... and you will know what I mean.
Look at a wall next to you when your driveing or just look at the widewalk, etc... when your driving both cars. Basically the projectors with HID's with cast a strong amount of light right in front of you with some light on the sides of the road. The OEM HID's will cast a equal amount of light all around you (in front and on the sides).
Maybe I have a picture around here showing what I mean.
[Modified by Rboosted717, 11:56 AM 12/25/2001]
Old Dec 25, 2001 | 10:58 AM
New User
So if I was to get Non-HID JDM Conversion, and then use a Philips 6000k kit, I should order the JDM Conversion with the HID Housings and just not the HIDs themselves?
Old Dec 25, 2001 | 11:04 AM
I'm not sure if you can just order the HID housings without the HID's.
If the cutt off beam is worth $1200 go for it. But the Philips kits with or without 6000k bulbs looks just fine. Heck I drove around with a US front with a HID kit for around a year, then I got the JDM front and put that kit on it for around a half of a year, then I got the OEM HID's because I had a killer chance to get them for extreamly cheep.
But yeah like I said. If you can spend or put the $1200 to something else thats needed for the car (engine mods, seats, hood, etc...) you might wanna do that because spending $1200 on lights might be a little much when you still have a way to go with performance mods.
spoonhatchblack
Mar 6, 2006 10:46 PM
JdmFront619
Dec 24, 2003 12:39 PM
SpoonSpecR
Jun 4, 2003 10:45 AM
FritzInTN
Sep 21, 2002 01:07 AM
ITR 2K
May 1, 2002 04:59 PM
