H-brace reviews
Old Nov 10, 2004 | 05:27 PM
redsled00's Avatar
Default H-brace reviews
Does anyone have any experience with the H-brace you install on the front bottom of your car? I'm thinking about getting one but I'm not sure if there is an improvement. I think the brace is probably as useful as a floor brace. I don't know. Any comments? thanks
Old Nov 10, 2004 | 05:36 PM
sohcvtec1995's Avatar
Default Re: H-brace reviews (redsled00)
I saw a improvement, Only cons on this is that it sits really low, and also you may have Header clearence issues. I had to cut a section of it out for my header to match up with the rest off my exhaust. Also install is a bt of a pain because it is a bit smaller then needed, but i guess thats to tighten up the front end.
Old Nov 10, 2004 | 06:16 PM
f1z1c's Avatar
Ebay ( ) one worked great for me. You feel the most improvement at highway speeds, especially in passing manuevers. They connect both LCAs to the floor member, so going over those small speed bumps are real noisy. You might have clearence issue with cat too depending on your setup. Mine fit tight, but enough headroom to not rattle anything. Installation was easier than I had read it was.
Thank the lord for spell check, because these margaritas are tasty. :
Old Nov 10, 2004 | 06:31 PM
Default Re: H-brace reviews (f1z1c)
I also have the ebay one. Some people on here say it is cheap and is not worth the money. But i have ran over things and gone off roading, and it has one small ding in it and a couple of scratches. Not bad for 50 buxs
Old Nov 10, 2004 | 06:47 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: H-brace reviews (sohcvtec1995)
Anybody feel more understeer after installation?
Old Nov 11, 2004 | 12:09 AM
cueballsi's Avatar
i got ebay special too.... DAm thing rattles my **** so much friekn annoying as hell..i think i am goign to cut it and re weld it next oil change
Old Nov 11, 2004 | 10:00 AM
redsled00's Avatar
Default Re: H-brace reviews (cueballsi)
So there is a noticable improvement with steering response?
Old Nov 18, 2004 | 11:59 AM
fucT's Avatar
So do you guys think this is a worthy part? I have a HiTech header, think there will be any clearance issues? The cat starts where the stock one would have ended (the header is a long tube). They're going for like 25.00 with like 19.00 s&h on http://www.ebay.com. They look exactly like the MeganRacing h-brace and have the same description.
Old Nov 18, 2004 | 12:21 PM
TheIntegraGuy's Avatar
I would like to know how the handling differs. I can imagine there would be crazy understeer with those things..
Old Nov 18, 2004 | 12:53 PM
MasterKwan's Avatar
Default Re: (TheIntegraGuy)
What makes you think it would increase understeer? As a brace, I'll bet it has minimal affect on under/oversteer. A big front sway bar on the other hand would increase understeer.
Old Nov 21, 2004 | 10:31 AM
f1z1c's Avatar
You notice the improvement at 65+ MPH in handling- the car seems to glide along without any corrections to the steering wheel. In idle my interior vibrates more. Tires are easy to spin too in launch.
M1K3
Honda Civic (2006 - 2015)
13
Jun 6, 2007 05:31 PM
gutted-dx
24
Apr 14, 2007 09:59 AM
veilsides2000
Jul 24, 2005 03:06 PM
civicgsr19
17
Feb 3, 2005 02:06 PM
ultimatehonda
Jan 8, 2003 11:42 AM
