Cheap way to keep a check on oil/tranny temps
So you take the temp on the sticker and add xxamount or are you just going for a rough estimate that will be off from what the fluid temp is going to be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Where did you get those strips? </TD></TR></TABLE>
local Nascar shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mltdown »</TD></TR><TR><TD CLASS="quote">So you take the temp on the sticker and add xxamount or are you just going for a rough estimate that will be off from what the fluid temp is going to be?</TD></TR></TABLE>
rough estimate = oil is about the same temp as the pan is since it is so thin.
the sticker has a 'rough' resolution so it is not that accurate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n »</TD></TR><TR><TD CLASS="quote">Willard: comments on temps?</TD></TR></TABLE>
ITR's suck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art Vandeleigh »</TD></TR><TR><TD CLASS="quote"> what would the deviation be from the temp of the case relative to the fluid temp. </TD></TR></TABLE>
who knows.
all I know is the oil is hotter than a m0-f0 after one easy track day at VIR-S.
a hard 3-day weekend at C.M.P. would = oil death.
local Nascar shop.
ITR's suck
who knows.
sorry to jack your thread, but i had a question about oil comsumption. my car constantly eats up a tremendous amount of oil in short periods of time and i was curious what you guys would consider to be "normal" in terms of quarts of oil consumed.
when i took my car in and they checked it, they said that i was within the boundaries of "normal consumption." i will withhold the amount to see what you guys say first. thanks
one qt. every 2000 miles seems to be the Acura limit.
I have burnt a qt. in one weekend of track driving.
[track weekend = ~110miles per tank x 2 days = ~220-->250 miles.
wow...i burn a quart every 750 miles and they say thats within the boundaries of normal. thats pretty eff'd up that they would just tell me that. i assumed that they would tell me the truth cause ive been going to them for the past ~4 years. im kinda pissed now...
Ross, I want your engine. Wanna trade?
As for temps, 250 degrees F does seem pretty high. And here I thought the ITR was designed to run cooler...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet »</TD></TR><TR><TD CLASS="quote">reusable? or once it records the higest temp, its done. (will not go back down onec its cool)?</TD></TR></TABLE>
once the color cell pops, it is done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">
once the color cell pops, it is done.</TD></TR></TABLE>
Pimp. Peak-hold styles...
How much? Sold per or in a big stack?
Essex and Pegasus should carry these pimp strips
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">a hard 3-day weekend at C.M.P. would = oil death.</TD></TR></TABLE>
I didnt have any problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy »</TD></TR><TR><TD CLASS="quote">As for temps, 250 degrees F does seem pretty high. And here I thought the ITR was designed to run cooler...</TD></TR></TABLE>
Why does it seem high?
RJ - burns maybe 1/2 qt per weekend (8-10 sessions).
Just hearing from some other people with oil temp gauges, 250 was on the high side. My opinion is based solely on their cars and their opinions though, so I could very well be mistaken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">250 is pretty high</TD></TR></TABLE>
If you dont know you dont care
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
i guess for you ignorance is bliss
I've only gotten my oil to 220 ish, on track, I definitely need an oil cooler, cuz my water and oil temperatures differ by A LOT
I noticed on friend's cars that have VTEC, the oil temp is considerably higher
I have a setrab oil cooler laying around that I will install, I just want to install a canton filter, and add a thermostat
</TD></TR></TABLE>i guess for you ignorance is bliss
I have a setrab oil cooler laying around that I will install, I just want to install a canton filter, and add a thermostat</TD></TR></TABLE>
I wouldn't bother with an oil thermostat. It's yet one more place for an oil leak, and if the thing malfunctions for any reason j00 could get stuck with no oil circulation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote"><----still a street car
don't u think the oil would get "too cold" w/o a thermostat</TD></TR></TABLE>
no...it wont be t00 cold, but it will take a bit longer to warm up....stick a piece of cardboard in front of oilc00ler in winter or something...
Drinker
