Dual Stage NOS system on a B18C1 Civic
Hey can a dual stage NOS system work on this car ?
I mean , run like a 30-shot for move off and crank up the 80-shot later on in the run ?
If I can be done how do you do it ?
Yep. It will work just fine.
With the help ofthis little gadget, you will have the effect you want.
It is a NOS programmable nitrous controller. It allows you to program the amount of nitrous flowing.
Or you can go with a dual or quad (depending on wet or dry) solenoid setup. This activates the first solenoid at WOT, and the other solenoid activates off of an RPM based switch.
Check out http://www.nosnitrous.com for more options.
[Modified by Big James, 11:17 AM 12/25/2001]
