which alternator do i need for 1 gen jdm B16a running with obd-1???
i have a 1st gen b16a that was converted to obd-1 and now i think my alternator is going out.. so i wanted to know which one would working on my car.. i believe i still have the original one on the car.. .. wondering if any b-series alternator would work ? need help !! thnkx for loking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">integra i believe. 90-93</TD></TR></TABLE>
yup... your ecu is converted to obd1 not all the wiring. so you need an obd0 alternator so it will plug into your wire harness.
so an integra 90-93... im trusting ur guys for this !! i ma look for that part now..
would u say it's hard to put in or it requires a lot skills ??
why not just take you alt down there and they can compare. but if i remember correctly they had different part numbers for the 90-91, 92, and 93 or at least thats what htey told me. i got a 90-91 but this was for an ls motor
but mine is jdm b16a alt...the part number should be different anyways right ??
the ls obd0 alternator is the same everyone has been telling you right...jdm b16 dont mean anything.plus i would say get a new one ive fried a few "used" dizzy and alterntors
yuo just need an alt from ANY bseries motor untill 96 (96+ are obd2 and have a diff plug)
but obd1 or obd0 distro will work...so anything from a 92-96 integra will work fine...
FYI
also even a d series alt will work fine, u just need some washers
FYI
thnkx !! hope i can get that **** fix tomorow..
cuz i've been push start this beast like a caveman !!
also driving dark with no headlight, the battery was only able to get a dim or the bumper light !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">yuo just need an alt from ANY bseries motor untill 96 (96+ are obd2 and have a diff plug)
FYI
also even a d series alt will work fine, u just need some washers ...</TD></TR></TABLE>
I used a d-series alt and washers for the bottom bolts
FYI
NugKaLj
Apr 23, 2008 04:22 PM
Sanj
Feb 19, 2007 04:21 PM
doublejz
Dec 2, 2003 08:21 PM
