SAFE TO DRIVE IN LIMP MODE??
my 99 em1 went limp on me yesterday and i need to take a trip for work hr drive there and another hr back...my vtec wont engage and my car is boosted is it ok to drive there and back in limp mode?
Yea depending on what code you threw you should be fine. If it is a important code and you try to get on it then there could be some problems.
i found the ecu codes here they are...
P1298 Electric Load Detector (ELD) Circuit High Voltage
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
i understand the o2 sensor ones but wat would the cause of the electric load be?
it will limit your RPM...like 3k and u will only run about 60mph or so
the eld. one is the main problem. that is electric load detector. im not fimilair with that code. but i know for sure. that can cause the 2 o2 sensor codes. cause whats the chances that both o2s can go out at the same time.
http://www.civicforums.com/forums/21...-detector.html
This should help. Good info.
According to that site, the eld reads the draw from the battery. Sound like your alternator might be bad or the eld is bad. Either way, you will either drain your battery and stop, or your alternator will work overtime and then will die, then you'll work off your batter till your car dies....
[QUOTE=hitvtecgetloud09;12395359]i found the ecu codes here they are...
I had this code and found out it was caused from a shorted out o2 sensor that got crushed and kept poping fuses under the dash
undertheradar
Dec 4, 2004 08:03 AM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
cyrixvsp2
Jun 10, 2003 05:02 AM
