question relating to my LS tranny
Guest
Posts: n/a
i have a LS tranny right now. mad tite 3rd gear grind Y0!!! so i wanna get rid of that. in my room, i have a j1 (xsi b16) tranny with a cracked case and a fucked diff. my question to you is......>> Can i put the b16 gears into my LS case and use the LS case and LS diff???? also, if that duznt work, can i put it into a ys1 casing and use my ls diff. ??cash isnt letting me buy the diff or case, but the ls one and ys1 case i have. pleeez help. if u view me , bump are appreciated.
Modified by DA_naut at 12:19 PM 11/17/2004
Modified by DA_naut at 12:20 PM 11/17/2004
B16 gears should be interchangable with the LS gears assuming your LS is a '90-'91. I'm by no means an expert on this, so someone please chime in if I'm mistaken.
BTW, I have a B16 J1 in my car, and the gearing is awesome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I don't think JDM tranny internals are compatible with USDM internals. </TD></TR></TABLE>
true i agree
u cant use b16 internals to b18 case...
true i agree
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS »</TD></TR><TR><TD CLASS="quote">
true i agree
</TD></TR></TABLE>can u explain why?
true i agree
true i agree
I'm pretty sure you can, as long as you use the corresponding synchros, etc. Someone please confirm.
true i agree
</TD></TR></TABLE>I'm pretty sure you can, as long as you use the corresponding synchros, etc. Someone please confirm.
