World Fastest Import Car is an Integra Typer R !!!!!
Old Dec 25, 2001 | 12:02 AM
DarthLuder's Avatar
New User
Default World Fastest Import Car is an Integra Typer R !!!!!
http://www.turbomagazine.com/archive...202_tech01.jsp
4000hp at 55psi
5.5sec 1/4 time
[Modified by O0oToOKo0Oo0OR555, 9:06 AM 12/25/2001]
Old Dec 25, 2001 | 12:04 AM
Type R's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (O0oToOKo0Oo0OR555)
yea i saw this before, but didnt know it was the worldest fastest import?! kool..
Old Dec 25, 2001 | 12:09 AM
nEoMuGen's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (Type R)
Is this a joke?
Old Dec 25, 2001 | 12:17 AM
Dee's Avatar
Dee
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (nEoMuGen)
too bad only the stretched outer skin is "Import".. everything else is derived from tried and true V-8 parts...
Old Dec 25, 2001 | 12:20 AM
Vtec integra's Avatar
did he cut a v8 block in half or is that a real type r motor?
Old Dec 25, 2001 | 12:22 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (Vtec integra)
It's like a 5.0 I-4, half of a V8.
Old Dec 25, 2001 | 12:26 AM
DarthLuder's Avatar
New User
I think its really just a Stretched Integra Type R shell. Plus he is using the Integra Type R name. Some dumbass out there goin to think the Integra Type R is the fastest import car out there.
Old Dec 25, 2001 | 12:29 AM
Tommy_Gunns's Avatar
I think it's an import motor cause he said the head had 16 valves...don't know, too lazy to read the whole thing.
Old Dec 25, 2001 | 12:30 AM
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (Tommy_Gunns)
Ah, I found the paragraph describing the motor:
The Type R's Max-4 engine is conceptually half of an Arias 500 cid Top-Fuel drag-racing V8, topped with an exotic triple-plug, four-valve-per-cylinder DOHC Batten Performance cylinder head. The engine is based on an immensely-strong aluminum block milled from solid billet without cooling passages--a mighty, solid-block dual-fuel powerplant designed to achieve 3,000 hp on 55 psi of twin-turbo boost, using nitromethane delivered in bulk via constant mechanical injection and trimmed with gigantic port electronic injectors.
EDIT: Half of 500 is 250 cubic inch...which translates to 4.1 litres
That's a pretty big 4 banger.
But for some reason they list it as 4.8 litres...
1 litre = 61 cubic inch <---this is a fact
[Modified by Tommy_Gunns, 3:43 AM 12/25/2001]
Old Dec 25, 2001 | 12:32 AM
Ross's Avatar
25 Year Member
Community Builder
This is just going to make more 16-yr old ITR owners want to turbo their cars. "If that guy got 3,000hp I can definitely get 1,000!"
Old Dec 25, 2001 | 12:35 AM
Dee's Avatar
Dee
"I had the technology," shrugs Norwood, who once did nitrous oxide scientific research and raced Top-Fuel Hemi dragsters with Dale Armstrong. "The Max-4 is half of what we already had in the Batten B-4 DOHC Chevy-Rat-type V8s. I decided to build a big four-banger with lots of cubic inches, good technology, really strong. I basically used a fuel-burning mentality for the block and the driveline and everything else.The Type R's Max-4 engine is conceptually half of an Arias 500 cid Top-Fuel drag-racing V8, topped with an exotic triple-plug, four-valve-per-cylinder DOHC Batten Performance cylinder head. The engine is based on an immensely-strong aluminum block milled from solid billet without cooling passages--a mighty, solid-block dual-fuel powerplant designed to achieve 3,000 hp on 55 psi of twin-turbo boost, using nitromethane delivered in bulk via constant mechanical injection and trimmed with gigantic port electronic injectors"
Come on people! Read the damn link! Did you even look at the billet cylinder block?
Old Dec 25, 2001 | 12:38 AM
Dee's Avatar
Dee
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (drealgsr)
it is half of the V-8 but it displaces 5.0 liters(4.5" bore x 4.5"stroke)..
[Modified by drealgsr, 1:38 AM 12/25/2001]
Old Dec 25, 2001 | 01:06 AM
Hapa DC5's Avatar
that's interesting, but i think that funny car integ is as much of an "import" as an accord. just the badging labels it an import lol.
Old Dec 25, 2001 | 03:27 AM
FusionITR's Avatar
whats the redline on that thing?
Old Dec 25, 2001 | 03:28 AM
Jason's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (FusionITR)
this has been posted like 3 times in the last week....
Old Dec 25, 2001 | 03:58 AM
Black SVT's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (typer98)
Call it what you want but I think it is still badass.Ugly,but bad.
Old Dec 25, 2001 | 05:27 AM
TypeR0149's Avatar
wow thats impressive, where can i order a 4.1 liter 4cyl, for my car
Old Dec 25, 2001 | 07:42 AM
mugenr#1011's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (Vegeta)
yeah that is pretty bad...
Old Dec 25, 2001 | 10:05 AM
Big Phat R's Avatar
All I can say is WOW
Old Dec 25, 2001 | 11:04 AM
sackdz's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (Big Phat R)
The front end is '97-spec... w00h00!
Old Dec 25, 2001 | 11:50 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (73rd 2000 ITR)
I like the fact that the block was CNC machined out of 1 very big piece of aluminum!!!
Old Dec 25, 2001 | 12:24 PM
aklucsarits's Avatar
New User
There is not one Honda part on that car...
Andrew
Old Dec 25, 2001 | 01:37 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (aklucsarits)
That is where you are wrong. The is at least one major Honda piece on the motor.
Hint: look at the electrical system.
[Modified by Mista Bone, 10:38 PM 12/25/2001]
Old Dec 25, 2001 | 02:04 PM
Bbasso's Avatar
did i read correctly???? 40 gallons per minuet??????????
Old Dec 25, 2001 | 02:24 PM
canuckr's Avatar
Default Re: World Fastest Import Car is an Integra Typer R !!!!! (Bbasso)
That thing is nutz, I like the 97 front end.
