msd install.
Old Nov 10, 2004 | 08:04 AM
willie_d18's Avatar
Default msd install.
i just installed a msd on my car. it starts but sometimes cut right off. when i 1st turned the car on the engine check light came on . and were do i run the wires out of the cap. right now i just got them running threw the crack were it seals
Old Nov 16, 2004 | 11:58 PM
del_orson's Avatar
Default Re: msd install. (willie_d18)
what msd ignition did you buy and what are you putting it on?
Old Nov 17, 2004 | 12:38 AM
hondaeg8's Avatar
Default Re: msd install. (del_orson)
don't run it through the crack
hehe.....drill a small hole in the cap and run the wires through there. you can cut through the wire when you tighten down the cap and that bare wire will touch the metal on the distributor.
Old Nov 22, 2004 | 09:02 PM
del_orson's Avatar
Default Re: msd install. (hondaeg8)
I notched the little rubber that holds the other wires coming through, that way you can still pull the cap off. Also I wired in connectors between the wires so that you can still pull the motor with out having to cut the wires. Clean
Old Nov 24, 2004 | 03:09 PM
willie_d18's Avatar
you thats a good idea with the connetors . i'll try that tomorrow
A13sechatch
Jun 8, 2010 09:10 AM
jazmie
Apr 1, 2010 01:14 PM
bobalee
Nov 2, 2006 05:25 PM
turboITR#704
Jun 6, 2003 11:17 AM
Acura_I-RS
Jun 6, 2002 03:57 PM
