SUB BOX
Old Nov 10, 2004 | 07:21 AM
Cowiebunga's Avatar
Default SUB BOX
Anyone put a custom sub box in the back of they crx? Send me pictures and way i can do it thanks!!!
Old Nov 10, 2004 | 07:25 AM
crx_88_si's Avatar
i made this one in the back of mine..
Old Nov 10, 2004 | 07:48 AM
Burlyirishdude's Avatar
Default Re: (crx_88_si)
that's really fucken clean. What amp? Does it rattle?
Old Nov 10, 2004 | 07:55 AM
crx_88_si's Avatar
using a fosgate 200.2 punch. the car has a few rattles (its an 88) but the actual sub box is extremely strong (and light).
I have an automatic garage door opener/closer.. i closed the door on the box, the door opened back up (dead man feature) and the box was untouched.
it's got more then enough bass for me.
Old Nov 10, 2004 | 08:00 AM
that's so sweet...how much does it weigh.. I have a bunch of OSB ....hehehe...and lots of fiberglass.....i want a 10"jl...in that box and that'll be enough for me to listen to ROCK 105.3 and all my CDS.....at volume 10 and make people jealous of my intake sucking their car under the hood, and then when they get tough with sound i can blow them into an embankment with sound waves.....
Old Nov 10, 2004 | 08:06 AM
crx_88_si's Avatar
w/o the sub, between 5-10lbs. not heavy at all, but REALLY strong.
what's "OSB"?
Old Nov 10, 2004 | 10:48 AM
Hcivic88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">w/o the sub, between 5-10lbs. not heavy at all, but REALLY strong.
what's "OSB"?</TD></TR></TABLE>
whats that controller for in the top of the picture?? looks like a neon controller to me.. lol...
box looks good btw.. i wanted to do something like that.. but i like to be able to remove my box fairly easily when i have to, and i like keeping my spare if i can
Old Nov 10, 2004 | 11:01 AM
T--Rex's Avatar
Default Re: SUB BOX (Cowiebunga)
Ok, this is my old setup, 2 kicker s12l7's with a kicker 800.2 amp, a pair of batteries, 1 on each sides of the box, 2 digital caps and a digital distributor block. I built the box to just fit in the rear of the car, it is 10 cubic feet, and it measured 20 x 20 x 30 I believe. When it was turned up, you could hardly breathe. But, as you can guess, it was heavy. And you can tell the car doesn't have the same pickup with it in.
Old Nov 10, 2004 | 11:10 AM
KaoticSnow's Avatar
I'm going to be building somting custom to get my 2 12" eclipse's in the back of my rex, now I've got some Ideas
Old Nov 10, 2004 | 04:41 PM
T--Rex's Avatar
bump for some more setups
Old Nov 10, 2004 | 05:33 PM
trrbl1bmx's Avatar
Default Re: SUB BOX (Matrix_Zero)
i like my sony door speakers!! they jam!
Old Nov 10, 2004 | 05:45 PM
propwdialogue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matrix_Zero &raquo;</TD></TR><TR><TD CLASS="quote">
overkill much? haha well put together setup though.
Old Nov 10, 2004 | 06:00 PM
mr_valentino20032000's Avatar
Default Re: SUB BOX (propwdialogue)
damn, i got a $60 special from Pep-boys, the 2 10" subs mounted in a box already, facing toward the back of the seats. Its powered by a rockford fosgate punch Amp. Its a nice clean bass when i want to listen, and when i want to show off i just turn it up
Old Nov 10, 2004 | 08:10 PM
T--Rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue &raquo;</TD></TR><TR><TD CLASS="quote">
overkill much? haha well put together setup though. </TD></TR></TABLE>
Thanks
Old Nov 10, 2004 | 08:20 PM
ALL4SPL's Avatar
If you dont mind the weight and losing the entire back hatch area, one of the most proven enclosures in a CRX is (External Dimensions) 29"x29"x14", two chambers, each chamber having 2 4" Aero ports that are 12" long flange end to flange end. This will work with either 12s or 10s.
Here is a pic of my box from 2002 db drag world finals.
Here is a pic of my box from last year in db drag racing.
And here is a pic of my current box for this year.
First one is 2 Resonant Engineering 12" SE's, I was the first competitor to take RE to db drag finals using their woofers. My certified SPL was 153.1 on the old termlab, and I placed 10th that year, which was also my first year at db drag finals.
Second one is 2 Kicker L7 12's and I had a certified score of 149.4db on the new termlab.
Last one is 2 Image Dynamics IDMAX 10s and I have a certified of 147.3db on the new termlab, and a certified 148.1db on the new Audio Control SPL190 mic currently the 5th loudest in the world in IASCA IDBL Stock 1.
Old Nov 10, 2004 | 08:37 PM
eda6's Avatar
This was in my hatch. Didn't fit after relocating battery. I'm going to make a new box and get a better sub. This box is filled with polyester and the driver is mass loaded. Mass loading lowers the resonant frequency of the driver (like kicker solobaric). Polyester makes the box seem bigger than it really is. Mass loading and polyester are ways to bring out the lows. When in the car the port faced forward. Box is 16x16x16=2 cu.ft. I was always fixing my rear view.
powerdbygarrett
Audio / Security / Video
Nov 20, 2006 11:53 AM
fleetmack
Jul 31, 2006 04:18 PM
4doorex
May 27, 2005 04:03 PM
loki2323
Nov 10, 2003 12:06 AM
GoLowDrew
Jul 28, 2001 09:52 AM
