Sleeve or Bore
Old Nov 10, 2004 | 05:33 AM
BigC-ivic's Avatar
Default Sleeve or Bore
OK, I have a b20... and I was thinking of sleeving it to 85mm
if I want to go to 86mm or larger do I have to bore out the block?
(or is this just a terrible idea)?
Old Nov 10, 2004 | 07:48 AM
mmuller's Avatar
Mad Scientist
Default Re: Sleeve or Bore (BigC-ivic)
if you sleeve, then 86 would be feasible
Old Nov 10, 2004 | 08:49 AM
justBLZE's Avatar
Chopper 2 Hopper
I would probably sleeve anything more than 84mm.
But that's just me.
Old Nov 10, 2004 | 09:01 AM
Fkned's Avatar
From what I've been told the stock sleeves on a B20 are joined together and don't make for a good resleeving job,I'd get an ls block to sleeve.
Old Nov 10, 2004 | 10:34 AM
BigC-ivic's Avatar
Default Re: Sleeve or Bore (Ed's Racing Heads)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed’s Racing Heads &raquo;</TD></TR><TR><TD CLASS="quote">From what I've been told the stock sleeves on a B20 are joined together and don't make for a good resleeving job,I'd get an ls block to sleeve.</TD></TR></TABLE>
I wonder if thats true?
Old Nov 10, 2004 | 12:31 PM
ExospeedAMcrx's Avatar
I used to have a picture archive on alot of block pics. Unfortunately, they got erased and I can't share what we had seen.
the B18 stock sleeves are better to work with. the foundation on the b20 sleeves are not as solid as the b18. If you're going to sleeve anyways, better use a b18 since its the same thing anyway after you sleeve it.
Old Nov 10, 2004 | 12:39 PM
BigC-ivic's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">I used to have a picture archive on alot of block pics. Unfortunately, they got erased and I can't share what we had seen.
the B18 stock sleeves are better to work with. the foundation on the b20 sleeves are not as solid as the b18. If you're going to sleeve anyways, better use a b18 since its the same thing anyway after you sleeve it. </TD></TR></TABLE>
too bad I already have a b20
Old Nov 10, 2004 | 12:48 PM
TrnsferErr's Avatar
Default Re: (BigC-ivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic &raquo;</TD></TR><TR><TD CLASS="quote">too bad I already have a b20</TD></TR></TABLE>
ill sell u a bare b18 for cheap
Old Nov 10, 2004 | 03:59 PM
its not that the B20 is NOT sleeveable. Its just a PREFERENCE to sleeve a b18.
Old Nov 10, 2004 | 08:18 PM
BigC-ivic's Avatar
Default Re: (TrnsferErr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrnsferErr &raquo;</TD></TR><TR><TD CLASS="quote">
ill sell u a bare b18 for cheap</TD></TR></TABLE>
thats OK, I have one sitting in my garage
Old Nov 10, 2004 | 08:19 PM
BigC-ivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">its not that the B20 is NOT sleeveable. Its just a PREFERENCE to sleeve a b18.
but aren't aftermerket sleeves made out of stronger material?
Why should it matter if I sleeve a b20 vs a b18
I'd still like some proof on this, everyone says don't do it, but no reason why
Old Nov 10, 2004 | 08:59 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">the B18 stock sleeves are better to work with. the foundation on the b20 sleeves are not as solid as the b18.</TD></TR></TABLE>
Old Nov 10, 2004 | 09:11 PM
I'd still like some proof on this, everyone says don't do it, but no reason why</TD></TR></TABLE>
Liek I said... I wish I still had those pictures to show.
BigC-ivic's Avatar
Default Re: (Ed's Racing Heads)
OK... so why isn't the foundation as solid?
I'm not trying to be a pain in the ***... I just want to know.
Old Nov 11, 2004 | 09:44 AM
ceLtic's Avatar
N/A wh0re!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic &raquo;</TD></TR><TR><TD CLASS="quote">OK... so why isn't the foundation as solid?
I'm not trying to be a pain in the ***... I just want to know.</TD></TR></TABLE>
because honda didnt mean to have a b20 rev out to 10k to make its peak power
duh. why didnt they? because they wanted torque.
why did they want torque? because it was going in an suv.
why did they make an suv? because honda wanted to an suv lineup.
re-iterating circle of retardation.
Old Nov 11, 2004 | 10:31 AM
BigC-ivic's Avatar
Default Re: (ceLtic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">
re-iterating circle of retardation. </TD></TR></TABLE>
what I mean is... what is it about the foundation that makes it weak (as compared to a b18)
and most of the b18s weren't buit to ver to 10,000 either
I don't want to rev my b20 to 10,000, I don't even want 8,000
EH3SiGRL
Nov 8, 2006 08:44 PM
spooncivic1
Aug 29, 2006 05:45 PM
-KangaRod-
Jun 24, 2004 02:29 PM
BI8B
Feb 24, 2004 09:46 AM
