del sol with home made turbo kit what kind of power?
Old Nov 10, 2004 | 04:33 AM
hong lo
Guest
Posts: n/a
Default del sol with home made turbo kit what kind of power?
I am in the process of doing a turbo kit in my girls car. She has a del sol (d16z6)and it had rod knock. So I went ahead and got the block bored and honed and bought eagle rods and wieseco pistons( 9.0-1) and am using a stock t-25 off a 99 eclipse gsx. The exhuast manifild is off a crx hf. I also have a conquest intercooler, also have dsm 450's. For engine management I will be using a vafc. What else will I need besides I/C piping to get it running good? Also what kind of power canI expect on 10-12 psi?
Old Nov 10, 2004 | 04:41 AM
SOHC_MShue's Avatar
Default Re: del sol with home made turbo kit what kind of power? (hong lo)
i would think that with 10-12psi that 200whp shouldn't be a problem.
Old Nov 10, 2004 | 05:00 AM
hong lo
Guest
Posts: n/a
Default Re: del sol with home made turbo kit what kind of power? (SOHC_MShue)
What kind of ET
Old Nov 10, 2004 | 10:20 AM
traction issuez's Avatar
hi-mid 13sss if your light enough and good enough driver. then you should break 100 mph at the end of the track.
Old Nov 10, 2004 | 06:38 PM
hong lo
Guest
Posts: n/a
Default Re: del sol with home made turbo kit what kind of power? (boostedrotary)
its for my girl she will love it!!!!
Old Nov 10, 2004 | 08:02 PM
rioninja's Avatar
Instead of the vafc, check out uberdata. Put the money you were going to spend on an afc towards a wideband.
Old Nov 11, 2004 | 01:26 AM
racinskittle's Avatar
Default Re: del sol with home made turbo kit what kind of power? (rioninja)
14.1@102 on 9.5psi in a del sol
Not that i'd know D16z6
EASILY 13's when i had it at 10psi and better driving. Damn honda tach and it being off by 500 RPM.
HackeN
24
Mar 1, 2010 06:36 AM
Han Solo
Oct 16, 2006 11:06 AM
10SecDSM
Sep 13, 2006 12:08 PM
90civichb
Jan 29, 2004 10:20 AM
